Thread: Pool alarm?
    Jan 2016
    Frisco
    6
    Pool alarm?
    Can anyone give some insight on those pool alarms - - the kind that either float in the pool or sit on the side that go off if a person falls in?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool alarm?
    Most have too many false alarms.
    For children, the type that require them to wear a bracelet work best if you can ensure that children wear the bracelets.
    The sonar based units work better than the float based units as far as false alarms.
    Annettebjrd's Avatar
    Apr 2016
    Lafayette Louisiana
    21
    Re: Pool alarm?
    I used a PoolGuard above ground pool alarm. Worked well with no false alarms, but I would take it out if the weather was really bad to make sure it would not go off. Model #PGRM-AG. Have an autistic daughter and was very worried about her wandering out to the pool. I keep high latches on all backyard doors and did lots of research before I chose this alarm.
    21 foot above ground round; 10,000 gallon; Pentair Dynamo 340210 1.5 HP pump; Pentair Sand Dollar Filter SD-60
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Re: Pool alarm?
    Great question!
    I've been researching primarily for my dogs, but seem to have hit a roadblock - they are under 10 lbs. following post for more info.
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
