Results 1 to 10 of 10
Thread: Help with my 1st SLAM
    Jun 2015
    Cashmere/WA
    12
    Water is cloudy, here are my #'s:
    FC .6
    CC .6
    PH 7.4
    TA 160
    CH 150
    CYA 60
    Temp 90
    Looks like I need to bring FC to 24
    That means I need 8 gallons of bleach????
    Outdoor, 16x42 28,000 gallon vinyl pool with 1.5 HP Hayward pump, Hayward Sand Filter, Heat Siphon Heat Pump, AquaRite T-Cell15 Chlorinator
    Aug 2014
    Northern IL
    4,615
    Re: Help with my 1st SLAM
    Yes. 8+ gallons. Cheap compared to pool store chems!!! Buy some extra to maintain the slam values. TFP recommends lowering pH to 7.2 before a slam. You're close at 7.4. Up to you on that.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    8 gallons is just the first dose. You'll need more to maintain 24 FC.
    Hopefully it won't be as bad as this
    Jun 2015
    Cashmere/WA
    12
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Uh-oh, hope recycle day is soon!
    Jun 2015
    Cashmere/WA
    12
    I got FC up for 30 (target was 24) and it went to 18 overnight. Do I bring it back up to 24 today and try again tonight with the OCLT?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    You should be checking/adding multiple times per day to keep it at 24. There is no need to OCLT until the water is clear.
    Pool School - SLAM - Shock Level And Maintain
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2015
    Cashmere/WA
    12
    Ok, the water is very clear, and has been for 2 days. It is a struggle to keep it at 24...
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    If it is a struggle to keep it at 24 that means it's being used up by something!
    How are your CC #s looking?
    DFW, TX
    24,509
    Since you need to test and add chlorine at night and in the morning anyway there is no reason not to.
