Results 1 to 10 of 10
Thread: Cheap chlorine
    Cheap chlorine
    FYI....Menards annual BOGO on chlorine is going on now....12.5% at $3.99.
    23,000 gallon gunite with waterfall, radiant heat, sta rite system 3 cartridge filter 450 sq. ft., 1 1/2 HP
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Cheap chlorine
    DING! Time to make the trip and get weird looks from customers and staff alike.
    Isolated Spa - 345 Gallons
    Feb 2014
    Central Minnesota
    5,080
    Re: Cheap chlorine
    Has it always said "Limit 6 free gallons per guest." on the ad? Don't think I've ever been held to that!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Cheap chlorine
    figures, not 1 store in OK
    Re: Cheap chlorine
    I just load up a cart...take to the car....go back in...load another cart....etc. Until I get to the 75 gallons or so I need for the season. They don't seem to mind.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: Cheap chlorine
    You buy your entire bleach for the season at one time?
    Dolphin E10 Cleaning Robot.
    Feb 2014
    Central Minnesota
    5,080
    Re: Cheap chlorine
    Quote Originally Posted by borjis View Post
    With 12.5% I wouldn't normally do that. The first purchase I usually make in May, the Julian dates are about 16085 - 16110 most years. I'll buy about 20 now. Then in July or so, I'll go and buy more either there or at Fleet Farm. By then the Julian dates are likely 16140+ so it's fresher. Incidentally, Fleet Farm used to have 4 gallons of 12.5% for $9.99 for most of the summer. It's $14.99 this year.
    Bought 16 gallons, there was only 1 on the shelf when I left. They had about 12 more on a pallet back in their staging area after I had loaded my cart. The Julian date on those was about 15 days newer but I didn't feel like reloading the cart again...
    Dec 2015
    Newington, Connecticut
    113
    Re: Cheap chlorine
    Ocean State Job Lot has 12.5 for 3.99
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    Re: Cheap chlorine
    I store it in my basement....usually stays around 65 degrees or so.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Cheap chlorine
    Thanks. I was checking add for store here, don't see BOGO, but is $3.99. Discription says 12.5% and-
    Liquid pool chlorinator is one of the best options to reduce cyanuric acid levels
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
