Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 112
Thread: New Pool Build Houston area
    Mar 2016
    Conroe, TX
    89
    Hi All,
    Wonderful site. I've been reading quite a bit here for a couple of months. Thanks to Wendy for letting me come see her pool and visit with her for a bit. Very much appreciated! We have narrowed our pool builder search down to two. I would like to know how these setups look to you all and what you would change. And/or which seems the better set up. Sorry, no pictures yet. Both come in close to the same price. Geometric style pool with raised wall and water feature. Sports pool. No spa. I'm most interested in how the equipment choices could be tweaked. Both builders Pentair equipment.
    Our yard slopes and Builder #1 says pool will come out of ground about 18 -24 inches unless we remove a couple of more trees. If we do that then they can grade behind the pool differently. Love the trees .
    Builder #2 says pool will come out of ground 4 feet and has placed extra structural costs in the build quote. Other 2 builders we got quotes from also felt 18-24 inches so the 4 foot thing is a little bothersome to us.
    Builder #1
    37 x 18.6, perimeter: 106', depth: 4-5.6-4
    IntelliFlo VS 3.0 hp pump (pool)
    Superflo 2.0 hp pump (water feature)
    CCP 520 Cartridge Filter
    IntelliChlor IC40 Salt system
    Racer Vac w/Boost Rite Pump
    2 LED Large Intellibrite Lights
    Dual Timeclocks w/freeze Protection
    LED light controls
    Belgard Pavers for decking 671 sq. ft.
    Builder #2
    34.6 x 16.7, perimeter: 91', depth: 4-5.6-4
    IntelliFlo XF pump
    CCP 420 Cartridge Filter
    Intellichlor IC40 Salt system
    Prowler 830 Vac
    3 color Globrite LED (we will likely eliminate one of these as the tanning shelf it would go would go away)
    Easy Touch4 Control Panel w/Freeze Protection
    Travertine Decking 712 sq. ft.
    Thanks for any input,
    Linda
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Re: New Pool Build Houston area
    Yay!!! No idea on the elevation issues. Travertine is so dreamy!
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    Mar 2016
    Conroe, TX
    89
    Wendy, you helped so much!!! My husband really wanted some kind of paver so...we asked about the pavers or travertine and they looked it up and said there was a paver war going on in our area and we could get it for $100 more than spraydeck. He is so happy!
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    I'm sooooo jealous!!!
    ~Wendy
    Feb 2016
    Houston
    323
    Paver war? Wow only $100 more! That is awesome!
    My pool thread. IG 31' x 20', 3.5'/4.5'/6', 8' spa, 4T moss rock WF/WW w/jumping rock, 7' x 11' sunshelf 3 bubblers, travertine coping, spray deck, Hayward equip: SwimClear 525 Cartridge Filter, H400 natural gas heater, Tristar Dual Speed EE pump 2HP, Tristar EE pump 1.5HP for water features, blower 2HP, Prologic P/S 8 w/aqua pod remote, Aqua Rite T-15 Salt System, Tigershark QC robot, networked Colorlogic LEDs 2 pool 1 spa.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    31,442
    What fun!
    The one thing that stands out to me is the one builder has a smaller filter...........always get bigger=less cleaning!
    I can't wait to see the pics. One thing you can do is share your current yard and show us the slope they are working with. It would be interesting to see why the one has the pool 4' out.....did they say why?
    Kim
    Aug 2014
    Houston tx
    2,530
    I believe the same goes for the salt cell, bigger is better. You may want to go with the IC60.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Mar 2016
    Conroe, TX
    89
    Pics of the backyard. Marla and Kim, thanks. That's what I thought too. Was wondering about the different pumps they chose and if it makes a huge difference.
    Mar 2016
    Conroe, TX
    89
    Pic of pool design we like best
    Apr 2016
    Wills point tx
    15
    I've been in the tree industry for the last 12 years. Own and operate here in Tx. We do pre construction consults. From reading what your options are it sounds like the trees that you our worried about wont have a great chance of survival through the construction process. I would take that into consideration before you spend the money on the extra 4ft wall with bracing expense. Any time you go into changing grade under the drip line you will drastically reduce the trees chance of survival. It may not be immediate but will start to decline shortly after. I love trees probably more than the next person but I still try to save people the time and money.
    Mar 2016
    Conroe, TX
    89
    Thanks Treewizard,
    That is a great concern of ours. The pine tree on the bottom picture (to the left) is coming down for sure. It's the three smaller trees to the left of that one that we thought we would try to not cut down. The pool will come to about where the pine tree is located. Could you give the picture another look and tell me if you think those three smaller ones need to come down?
    We are willing to go ahead and cut them down- just not wanting to.
    Wills Point is east of Dallas, right?
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Can you ask each builder to spec out the other builders proposal, such that you get two apples/apples comparisons?
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Your backyard is gorgeous! Hmmm infinity edge overlooking the beauty.
    ~Wendy
    Jan 2011
    Richmond, Texas
    595
    Quote Originally Posted by Slm3rob View Post
    That is some beautiful St. Augustine grass.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Jul 2012
    Tallahassee, FL
    31,442
    Quote Originally Posted by txnole View Post
    LOVE this idea! Also sit down with the 4 ft one and ask what they are thinking and why.
    Quote Originally Posted by Sunbaby View Post
    OH YEAH! No blocking the veiw!
    Quote Originally Posted by Flippy View Post
    hehe that is the first thing I thought of when I saw the pictures "man that is some pretty grass!" But hey my weeds are green so LOL
    Kim
    Mar 2016
    Conroe, TX
    89
    Spoke with the actual pool builder (salesman said 4ft and that's what they went by when they drew up the plans). He came and measured the yard and said what all the others said- 18 - 24 " out of the ground. So that's better.
    They are reworking the plans too. So we'll see what they come up with.
    And yes, the grass is beautiful right now. Thanks to my husband!
    Jul 2012
    Tallahassee, FL
    31,442
    Cool! I can't wait to see the plans and help you pick the best one!
    Kim
    Mar 2016
    Conroe, TX
    89
    We are starting to build in a couple of weeks. We had a couple questions if anyone has time to give me their opinion.
    The pool will be SWG about 21,000 gallons. The Builder has listed in the equipment an IC40 salt cell AND an Intellichlor . We think this is overkill. When I questioned it they said the intellichlor was in case the SWG failed, we would have a backup system. I also asked for the price difference to upgrade to the IC 60. They told me they a
    the IC40 is more than enough and the 60 would generate 2lbs of chlorine a day (24 hours) which would be too much for our size pool. So my Two questions:
    1. Is the Intellichlor necessary and
    2. Should we try to upgrade to the IC60 (we know we would not run the SWG 24 hours a day.
    thanks!
    Linda
    Jul 2012
    Tallahassee, FL
    31,442
    The bigger the cell for the SWG the less it will have to work/run thus saving you money on the power bill.
    I don't know enough about the other system in question. I will let someone else answer that one.
    Kim
  20. Back To Top    #20
    Aug 2014
    Houston tx
    2,530
    I run my salt cell everyday. It's how the pool is sanitized. You can control the percentage of salt so it's making just the right amount of chlorine for your pool. TFP has charts you'll want to print out and use as references. I would still go with the larger cell and dump the inline Chlorinator. You won't be using salt until 28 days after plaster. Who will be maintaing your pool after start up?
    Marla
