Thread: Which first....TA or Ph?
    Duh..... I forgot...which one first? TA or Ph?
    Sami
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    Jun 2014
    15,153
    Re: Which first....TA or Ph?
    pH is usually more critical. Get that in the mid 7s first, then you can tackle TA slowly as needed.
    Thanks Texas Splash!! You guys are the best !!!
    Sami
    38,299
    The real answer is that it depends
    If your TA is 0 or negative, then you want to raise the TA some first.
    Got it !!
    Thanks jblizzle !!!!
    Sami
