Thread: Opening pool robot question
    Can I put the robot in and put it on before adding any chemicals? I am assuming yes since it says to keep it below 4 chlorine.
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Opening pool robot question
    Yes. It will help mix any chemicals you do add. And the 4 FC is with zero CYA. That's actually way strong, like shock level. If you keep FC below shock level for your CYA, the robot will be fine. Unbuffered chlorine is what's so rough on robots and swimsuits and eyes.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Predator, what's your water temp? Just so you know, last year I put the robot in service on opening and while it went through the motions, it went Veeeeeeerrrrrry verrrrrrry slowly Apparently its not fond of water in the 40s. Somewhere in the manual, it confirmed this. So don't be alarmed if yours does this -- its not broken, its just protesting
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
