Results 1 to 7 of 7
Thread: Poolmath app for smartphone
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Any plans to build a poolmath app ?
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Re: Poolmath app for smartphone
    Quote Originally Posted by dw9000 View Post
    Yep, search for Pool Pal -- its a GREAT app and it seems to match the online calculator exactly.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Quote Originally Posted by Helen203 View Post
    Ok, thanks I will try it
    Cartridge Filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I open Poolmath in a browser on my phone.
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    363
    Android only?
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Flbeachluvr View Post
    Android only?
    I believe so. The simplest solution for Apple users (and all device types with a browser for that matter) is to save the Pool Math webpage locally on your phone. That way, even if you don't have cell signal or wifi, you can still use the page. No need for an app either.
    Isolated Spa - 345 Gallons
    Jul 2015
    Merced ca
    1
    Try pool calc in the apple App Store it's free
