Thread: Jandy Aqualink won't turn on
    Jun 2015
    Murfreesboro
    29
    My jandy Aqualink panel was working. I turned it off to clean the main skimmers. Now it won't turn it on again.
    38,524
    Re: Jandy Aqualink won't turn on
    You check the breaker? Or a GFCI supply?
    Jun 2015
    Murfreesboro
    29
    Yes have checked the breakers and are on
    Apr 2013
    Sacramento, CA
    2,769
    How about the GFCI? If the panel breakers are not GFCI then there is an outlet near or attached to the panel that has a GFCI test button and a reset. hit test then reset.
    Jun 2015
    Murfreesboro
    29
    gwegan
    I tested the GFCI buttons and reset it and now it is working. I am so Thankful for your help.
    Apr 2013
    Sacramento, CA
    2,769
    Occasionally one of my ideas works. Glad it worked.
