Results 1 to 8 of 8
Thread: Vinyl Pool Cracks
    Feb 2016
    Albany/NY
    91
    Vinyl Pool Cracks
    Does anyone know if this applies to vinyl liner pools as well as ours has some cracks as well.
    Starting Monday 4/18/16...18x39x30x14 L vinyl liner pool. All Hayward equipment: Tristar pump, 300K BTU heater, s310 sand filter, T-15 swg, Omnilogic. 2-12v universal color logic lights + 1-320 accent light on the steps, Latham gold pebble liner. Tf-100 test kit
    Apr 2013
    Sacramento, CA
    2,769
    Re: New Pool Construction - Concrete Cracking
    liner pools are completely different animals.
    Where do you see cracking, how is your pool constructed and do you have pictures?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Time out. Let the mods move this to its own thread so the OP's thread doesn't get hijacked. Should happen soon. Thanks!
    Feb 2016
    Albany/NY
    91
    Quote Originally Posted by gwegan View Post
    Quote Originally Posted by pooldv View Post
    thanks, I didn't mean to hijack, I was just concerned
    Apr 2013
    Sacramento, CA
    2,769
    Re: Vinyl Pool Cracks
    Karen so describe your pool and post some pictures
    Feb 2016
    Albany/NY
    91
    this is a picture from the day after they poured the bottom for our vinyl liner in ground pool. Is this normal?
    Apr 2013
    Sacramento, CA
    2,769
    I would say that is not normal. Was it a hot day? What does your Pool Builder say? That's in the hopper correct?
    How much of an effect it will have on your pool is difficult to say. That appears to be more than surface cracking.
    Feb 2016
    Albany/NY
    91
    this is the floor of the shallow area. As for temperature, it was about 65-70 when they poured this. we have not discussed this with the pb yet because there were other issues that came up first.
