Thread: Kreepy Krawler
    Progers's Avatar
    Mar 2016
    Lafitte,Louisiana
    93
    Kreepy Krawler
    Kreepy krawler
    Just purchased can anyone give me any advice on it. It's seems to stay on the same path.
    10,000 Gallon AG,Pentair Sand Filter,Built 2013, TF-100,No Restrictions
    22,550
    Re: Kreepy Krawler
    Are you redirecting the return eyeball to see if that helps? If you're using a skimmer plate, sometimes rotating it in the skimmer slightly makes the KK go a different route.
    klynch494's Avatar
    Aug 2015
    Twin Cities/MN
    96
    Re: Kreepy Krawler
    Depending upon which kreepy krauly you have, some have a small slide adjustment on the bottom corresponding with different numbers. It changes the pattern from bigger circles to smaller ones. I have the shark and it does best on the smaller tighter circles. Also keeps it from getting caught up on the foam cove.
    ~Kevin (MN)
    13.5k gal, 24' Round AG Vinyl
    2HP Waterway Pump, 200sqft Hayward Element Filter
    BBB Method & AuquaSmarte Inline Chlorinator, TF-100 Test Kit
    Kevin, TFP Believer & Supporter
    (Yup, I drank the pool water)
    13.5K gal, 24' Round AG Vinyl, TF-100 Test Kit
    2HP Waterway Pump, 200 SqFt Hayward Element Filter
    Recommendations: Pool School, TFTestkits & Pool Math
    klynch494's Avatar
    Aug 2015
    Twin Cities/MN
    96
    Re: Kreepy Krawler
    Actually running the shark right now. He's smiling back at you from about 20 feet out and 4 feet deep...gotta love that Trouble Free Pool crystal clear water!
    ~Kevin (MN)
    Progers's Avatar
    Mar 2016
    Lafitte,Louisiana
    93
    Re: Kreepy Krawler
    I have it in skimmer and the adjustment is done in a connection so I will have to play with a little more.
    how long do you leave it in for when cleaning?
    klynch494's Avatar
    Aug 2015
    Twin Cities/MN
    96
    Re: Kreepy Krawler
    Anywhere between 6 and 8 hours once a week after i brush... it sometimes just depends upon what I'm doing and how good I think it did
    ~Kevin (MN)
