Results 1 to 13 of 13
Thread: AGP first opening
    lovestoswim's Avatar
    May 2015
    Milford, Ohio
    102
    AGP first opening
    We became pool owners last year.
    Closed mid November and took the cover off today to begin opening procedures. So happy to see clear pool with just a few leaves to scoop out and need to do a little vacuming. All thanks to TFP method 😎
    24,000 gallon, 21x43 Oval Wilbur AGP installed June 2015. 10'X24' deck. 2hp Aqua Pro Cartridge Filter. Using TFP method.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: AGP first opening
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    SWEET! I love it when this kind of thing happens! Make life easier and cheaper! LOL
    Kim
    Jun 2014
    15,176
    Nice. Have a great swimming season.
    May 2015
    Milford, Ohio
    102
    Thanks All - two hoses in now. FC at 15 and ph is 7.2 ������. Yippee!!!
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    Quote Originally Posted by lovestoswim View Post
    ph test is unreliable when chlorine is at shock level
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    May 2015
    Milford, Ohio
    102
    Quote Originally Posted by Skitch View Post
    thank you skitch....I didn't know that about the ph. After filling chlorine dropped to 5 and ph still at 7.2 - water temp is 60 now...and going to get cooler this week. I wasn't sure if I still needed to slam with water temps so low. My Water looks great! Wish we had a heater...i would be swimming!
    Jul 2012
    Tallahassee, FL
    30,539
    The cooler temps will make the SLAM go faster due to the algae having the cooler temps and chlorine to fight at the same time.
    Kim
    May 2015
    Milford, Ohio
    102
    Quote Originally Posted by kimkats View Post
    Kim
    I didn't lose any chlorine over night - do I continue with slam or just keep chlorine levels normal? Thanks
    Jul 2012
    Tallahassee, FL
    30,539
    So you did not lose any FC over night and your water looks great................do you have any CC? You can have .5 but no more. IF you have less that .5 CC you are done with the SLAM!
    Kim
    May 2015
    Milford, Ohio
    102
    Kim
    Suweet!!! Where's the easy button - I'm done with SLAM!! Thank you for your help!
    Jun 2014
    15,176
    May 2015
    Milford, Ohio
    102
    Quote Originally Posted by Texas Splash View Post
    Yay!!!
