Thread: Leveling pavers
    Leveling pavers
    Should the paver be leveled by dirt or is pea gravel safe to use?
    Currently a big sand box with no pool, 18"x54 on order
    Hayward EC40 filter with Hayward 1HP pump, Wanda the Whale
    SWG
    Jul 2015
    Central Valley CA
    1,109
    Re: Leveling pavers
    usually sand made out of crushed stone on top of a base of rock. Any gravel / dirt yard will have paver sand
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Apr 2013
    Sacramento, CA
    2,769
    Re: Leveling pavers
    As Attech says any sand made from crushed stone will work. In smaller quantities you can buy it in the garden section of HD or Lowes although it is obscenely expensive.
    Re: Leveling pavers
    Didnt even need the crushed stone. Out of 12 pavers only 3 werent level. Worst I had was a 1/4" off
    SWG
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    Re: Leveling pavers
    next time, If there is a next time. I will pour concrete
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Casey's Avatar
    SW PA
    10,453
    Re: Leveling pavers
    Quote Originally Posted by pensfan76 View Post
    Sent from my SM-G900V using Tapatalk
    Glad that's over with huh?! LOL
