Thread: Tanning Ledge..
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Tanning Ledge..
    I have some rough plaster on my tanning bed, I am going to drain it down to below the ledge for tile install. Is there anything to smooth out the rough plaster? Thanks
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Tanning Ledge..
    My husband says "what about wet sanding?" That was his first thought when I asked him. He says do it like you would wet sand a car. I bet a search will pull something up. Just be ready for a kind of mess with the plaster you sand off but it should be easy to vacuum up.
    Kim
