Thread: Pool water temps and testing CYA levels
    Dec 2015
    Newington, Connecticut
    113
    Is it practical to test the CYA levels if the water temps are below 60 degrees? Not sure if cold temps effect the CYA levels.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pool water temps and testing CYA levels
    Lower water temps do affect the test, you can bring a sample inside and let warm up to do the test, I let mine get to about 70 degrees and tested just fine..
    Dec 2015
    113
    Great idea will do, thanks alol
