Results 1 to 7 of 7
Thread: Anyone know of a good quality suction side cleaner??????
    I tried a lot of them but they just get stuck...hoses leak..don't climb or its something......any ideas??
    13000 gallon fiberglass, cartridge filters pentair Intelliflo Variable speed Programmable Pump separate booster pump solar panels on roof
    Feb 2015
    Chandler AZ
    925
    Re: Anyone know of a good quality suction side cleaner??????
    Several members here like ThePoolCleaner. They are available as 2 wheel or 4 wheel - selection depends on pool depth. I believe that Hayward bought the company about a year or so ago. Hayward has come out with a "newer" model called the AquaNaut - also available in 2 or 4 wheel. The originals are still available online from various sources and usually cost a bit less than the newer models.
    You may wish to do a search here to see if anyone uses one of these with a fiberglass pool such as yours.
    Do you still have your MX8? If so, exactly what issues are you having with it?
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    thanks provia will do
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    More and more folks are ditching the cleaners and going to robots. Most seem to really like their robots. I haven't yet so no recommendations on brands from me.
    Feb 2015
    Chandler AZ
    925
    If you still have the MX8, you can also check to see if they make different tires/treads that are possibly better suited to fiberglass. Also, search here for members who may have the MX8 and discuss any issues you have directly with them. If you can get it to work acceptably, no use spending $$$ on a new cleaner
    As pooldv stated, many members love their robots. They are a bit pricier though. Have a read through some of the threads in the Pool Cleaners forum.
    Gene
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Quote Originally Posted by dansdad View Post
    I went with the 2 wheel version of ThePoolCleaner several years ago and couldn't be happier. Prior to buying that, I had the Polaris 360 and spent a lot of time repairing it. For a solid 4 years, it has done a terrific job. One issue I was happy to see go away was the common problem of the cleaner getting stuck at one end. Happy to say this is a thing of the past.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I use the Krepee Krawley for about 10 years now went through 3 of them .
    There is a reason they still make them after all these years !!!
    There so simple, only 1 moving part ...and they clean pretty good ..
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
