Thread: Pool volume calculation question
    Sep 2015
    Phoenix, AZ
    17
    Can someone help with the volume calculation. average depth is 4 feet ish. I used kidney bean calc puts me at 14,720 gallon. anyone else?
    IG Gunite play pool 15k gallon 20' x 30' , System:3 cartridge filter S8M150, Stenner pump, Fiber optic lights 3 head with color wheel, TF-100 Testkit, CYA-50, FC-6, CH-375, TA-40, PH-7.8
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Pool volume calculation question
    I come up with 15643 gallons. But even if I did the math perfectly, I didn't allow for the steps, so I know I'm over.
    38,524
    Just use 15k and see whether you consistently hit your chemical targets. If not, change volume PoolMath.
