- Jun 12, 2011
- 3,763
- Plaster
- Pureline Crystal Pure 60,000
3 Questions regarding SWGs.
1. Since my pool is only 9700 gallons would the Hayward AQR9 be good (25000 gallons) or would it be better to buck up and get the AQR15 (40000 gallons)? The 9 could probably keep up with the day to day needs of the pool, but buying the larger T-15 would be the better value. It doesn't cost too much more and will put out way more chlorine over its life cycle. So day to day, you would be running the SWG at a lower setting to produce the same amount of chlorine and the cell would last years longer.
2. Does the SWG need to be hooked up to a timer or does it only work when water is flowing through it? Yes and Yes. If running a single speed pump it would be hooked to the same timer as the pump, so it only see power when the pump is running. With a VS pump that is controlled by an onboard timer, a seperate timer should supply power to the SWG only when the pump is running. The SWG does have a flow switch which prevents it from working when there is no flow, but that is designed as a safety feature and shouldn't be depended on as the primary control
3. Can you shock at a lower CYA level and bring it up to the 60-80 range after? Yes
RE. Plumbing, the SWG should be the last thing before the water returns to the pool.
