Results 1 to 8 of 8
Thread: Never adjusted PH?
    May 2015
    Gulfport, MS
    109
    Never adjusted PH?
    I have owned my pool for a year and have never had to adjust PH, is this normal? It always reads 7.5. Im not complaining but I just thought this was something I would need to do on occasion.
    12X20x54" Saltwater 8000 semi-inground, Waterway 1.5hp 2speed 22" Pump Sand Filter, Hayward Goldline Aquatrol HP SWG, TF100
    Dec 2015
    arlington, tx
    100
    Re: Never adjusted PH?
    what are your chemistry numbers???
    JoyfulNoise's Avatar
    May 2015
    13,199
    What's your fill water chemistry like?
    Matt
    Aug 2014
    Shallotte, NC
    693
    Yeah, if you could give us the numbers on your fill water, pool water, and pool type, we could give some thoughts. Personally, I can go from opening to closing, with no adjustment to pH... assuming we don't get a ton of rain that causes me to dump water.
    On second thought, it might be well to disclose your pH testing method(s), too...
    Aug 2014
    Northern IL
    4,615
    It's curious with a SWG. I have not adjusted my pH in about 2 years.
    Sep 2013
    Charleston, SC
    537
    I also don't have to adjust my PH and I have a SWG. Once I got my TA where my pool is happy, I maybe add MA once a season.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    I'm only just now starting my second season, but all of last Summer I never had any Ph issue once taking over the pool and firing the pool guy. The only time I had to play around with it was in the process of adding borates. It stayed right around 7.5 to 7.6 all summer with no adjustments.
    However, like others have asked, the rest of your picture would help them. In my case even my top-off source water has a TA of only 50, and the pool was at 60 most of the Summer. That combined with the buffering of the borates ended up with everything simply settling where I was happy with it.
    I have only started trying to get things set to use the pool this year and my own TA down to 50 and Ph still at 7.5, but borates low so I need to figure out that one but am pretty confident it will settle right back down. I got lucky with our source water and feel sorry for those who have to fight against it
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    How quickly your pH rises (or not), depends on a couple things, most notably, the pH of your fill water and then the TA of your water.
    The TA buffers how quickly the pH rises. Generally speaking, lower TA numbers in the 50-60 range, although outside of TFP recommendations, work very well at pH buffering in Vinyl pools where worries of CSI isn't a big factor.
    It wouldn't suprise me that if you tested your TA, you would find this might be the case.
    I would be surprised if your TA is above 70, and have never had to adjust the pH.
    I have a vinyl pool IG pool, My TA stays between 50 and 60, and my pH has been steady at about 7.4 - 7.5 for 3 years now. I also have a SWG.
    Divin Dave,
