- Jun 22, 2014
- 47,890
- Fiberglass
- CircuPool RJ-45 Plus
Even with a cover, you still want the FC to match the corresponding CYA based on the Chlorine/CYA Chart. It just means that with a cover you should lose much less FC each day to direct sunlight. So always go back to that chart and make sure the FC and CYA match - in your case for a SWG-pool
Have you tried linking your photos from Photobucket? That's what many of us do here on TFP. Upload your pics to Photobucket (free), then copy & paste the IMG code for that pic from Photobucket to your TFP post. Works great.
Also, you can try going to the bottom of your quick reply post where it says “Go Advanced”, and then down to where it says “Manage Attachments”. It may let you upload them that way. They may show-up large because you can't adjust the size of the attachment, but it may work.
