Thread: Pentair filter question
    Jul 2014
    Raleigh, NC
    59
    Does anyone know what the difference is in the Pentair Clean and Clear 150 and the 200 filter? The parts list shows that they have the same dimensions. Will the 200 fit in the 150 housing?
    32,000 gallon inground plaster pool/spa combo spillover. Aqua Rite Pro with Sense and Dispense. Jandy iAquaLink Control. Polaris 280 vac. Sheer Descent, Fiber optic deck jet water feature. Vanishing wall. Whisperflo pumps, Pentair clean and clear cartridge filters.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Pentair filter question
    150 and 200 are the square feet of the filter. So the filter in the 200 is 50 square feet bigger. I believe the 150 has a 6" diameter cartridge and the 200 has a 10" diameter cartridge.
    It seems possible that the 200 might fit in the 150 since the housings are the same size and the filter is the same height. The only thing I would think is important to check is the inside diameter of the cartridge. I couldn't find that in a quick search.
