Page 1 of 8 1234 ... LastLast
Results 1 to 20 of 159
Thread: New pool build in CA
    Jan 2016
    Sonora, California
    147
    Well I figured I should start a build thread to keep track of our project. Started getting bids and designs July of 2015, signed the contract in October and started the dig in January due to weather delay. The pool is 42ft long, 24ft wide in the shallow end and 18ft wide in the deep end with a diving board. The week we were supposed to gunite we added a 7ft hot tub so it got pushed back to today. Here are the pictures so far:
    Day of the dig:
    Jun 2014
    15,298
    Re: New pool build in CA
    We enjoy pics that's for sure. Looks to be a very nice project. We'll be anxious to see the outcome ... as I am sure you are as well.
    Apr 2013
    Sacramento, CA
    2,769
    That is a big pool!. Looking good.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Thanks for letting us come along for the ride!
    Kim
    Jan 2016
    Sonora, California
    147
    Heavy night of rain filled the deep end:
    Pool plumbing complete:
    Pool Rebar complete:
    Decided to add the hot tub:
    Hot tub Rebar complete:
    All ready for Gunite:
    Plumbing tucked away under our deck:
    Jan 2016
    Sonora, California
    147
    Today was Gunite day!!
    These guys work their butts off, started at 6:30am and didn't leave until 5:00pm. Tomorrow morning I get to start watering it down......
    Aug 2014
    Northern IL
    4,615
    Sweet looking pool project! What is your start-up procedure?
    Jan 2016
    Sonora, California
    147
    Quote Originally Posted by MarianParoo View Post
    Start up procedure??
    Aug 2014
    Northern IL
    4,615
    Here is a link to START some reading: A Bicarb Start-up guide for TFP members. BTW, do you have a good test kit yet? Pool School - Test Kits Compared
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Pool School - Start-up New Plaster
    Bicarb seems to be the preference.
    Jan 2016
    Sonora, California
    147
    I will have to talk with my PB about what his plans are once the pebble is installed.
    No test kit yet, what would you recommend for a salt system?
    Thanks for the replies!
    Under Construction - Free form in-ground pool/spa, 24x42, 815 sq ft, 119' perimeter, 3.5-8 ft depth, 26,500 gallons, Triton II sand filter, IntelliChlor SWG, 3 Intellibrite LED lights, IntelliFlo VS pump, Easy Touch Control System, raised planter box & patio space TBD........
    Jul 2012
    Tallahassee, FL
    30,672
    TFTestkits.net
    Here is a link to THE test kit we use and love. It is the best bang for the buck. It has more of the tests you will do daily. I am not sure about which to get for the salt system. It lists two tests. I will be watching to see what others say about buying both or one and why.
    Kim
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    How big is that pool -- it looks huge!! The curvy edges look pretty!
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Jan 2016
    Sonora, California
    147
    Quote Originally Posted by Helen203 View Post
    The pool is roughly 42th long, 24ft wide at the shallow end and 18ft wide at the deep end. The hot tub is 7ft in diameter. Not sure about how many gallons, never bothered to ask the PB.
    DFW, TX
    24,516
    I use the Aquatest salt strips, I think I've only used about 5 in 3-1/2 years. Salt tests have a wide margin of error and so does your SWG, both can vary by several hundred ppm. And my SWG works fine with the salt level anywhere from 3000 ppm to 4500 ppm. Salt is about getting into the ballpark, not precision. Ultimately, if your SWG is happy, making chlorine and not reporting hi/lo salt error the it doesn't really matter how many ppm of salt is in the pool.
    Jan 2016
    Houston/Texas
    11
    How many gallons?
    39k gallon, Pebble Tec, waterfall spa, Pentair FNS60, Del Ozone, K-2006, built 2013, The Woodlands, Texas
    My Pool in Houston, TX:
    39,000 gallon, Pebble Tec, inground, spa, Pentair DE filter, Del Ozone, cleaner, 3 years old
    Aug 2014
    Houston tx
    2,525
    So dv are you saying we don't need to purchase the salt test?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Dec 2015
    Severna Park, MD
    78
    Very nice build pics
    Thanks fit sharing
    Sent by incredibly fast electrons
    Jan 2016
    Sonora, California
    147
    Thank you, waterline tile and coping stone will be started once this rain storm passes.
  20. Back To Top    #20
    Jan 2016
    Sonora, California
    147
    Pool tile was installed today and the coping stone delivered. Have a few areas of grout lines and cut pieces that will need fixing. Other than that it's looking good.
