Results 1 to 11 of 11
Thread: Raise CYA
    Mar 2012
    Boerne, Texas
    20
    Raise CYA
    What is the best way to raise CYA? I've got stabilizer in a sock but how long should I leave it in there? I don't think I have any CYA.
    Pool size = 16,000 gal, IG Fiberglass, 2 speed hayward pump with cartridge filter
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Raise CYA
    Quote Originally Posted by Texgal View Post
    You "don't think"? Have you tested for it?
    We base our pool care system on accurate testing and only adding what the pool needs, when it needs it. To do that you need your own accurate test kit. Order a TF100.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Support the site
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Re: Raise CYA
    What makes you think there is no CYA? How are you testing?
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Raise CYA
    Depending on the brand, the stabilizer should all be dissolved anywhere between a day and a week. You can either set the sock in the skimmer basket (as long as it doesn't starve the pump and you leave the pump on the whole time) or suspend it in front of a return. Either way works. The key is to get a lot of water forced through it.
    How did you test for CYA?
    If you or the pool service or the previous owners chlorinated with pucks, you have some CYA in the water. If it's just been filled, you won't have any, because CYA doesn't exist in nature and shouldn't be in any municipal water systems.
    A couple possibilities for the CYA sock.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: Raise CYA
    I did a cya addition in a day.
    I put the sock in the skimmer basket, pump running and let it sit for 4 hours.
    After that time the cya was very squishy, i kept squeezing it in every direction
    while submerged in the skimmer and it was totally dissolved within 10 minutes.
    I did have sore forearms the next day!
    Dolphin E10 Cleaning Robot.
    Jul 2012
    Tallahassee, FL
    30,476
    Re: Raise CYA
    LOL borjis I walked around my pool and put mine in! My hand and forearms where very sore BUT TFP said to put xx amount so it was going in!
    Kim
    Jun 2014
    15,103
    Re: Raise CYA
    Hello Texgal! Looks like we have similar type pools and equipment. When you get a chance, please update your TX location (city). As you can expect, there's a big temperature difference between DFW and San Antonio. You'd be surprised how much that helps as we review your posts. As for the CYA - happy soaking! Have a nice weekend.
    Mar 2012
    Boerne, Texas
    20
    Re: Raise CYA
    Texas Splash,
    How right you are about the temp!. I'm in Boerne, outside of San Antonio
    Last edited by Texgal; 02-06-2016 at 09:51 AM. Reason: I don't know what I'm doing!
    Mar 2012
    Boerne, Texas
    20
    Re: Raise CYA
    Thank you for the pictures, that was very helpful. Mine is in the skimmer (I had nothing to tie too) but I'm worried about it. I will use your suggestions!
    QUOTE=Richard320;964619]Depending on the brand, the stabilizer should all be dissolved anywhere between a day and a week. You can either set the sock in the skimmer basket (as long as it doesn't starve the pump and you leave the pump on the whole time) or suspend it in front of a return. Either way works. The key is to get a lot of water forced through it.
    [/QUOTE]
    I filled the little tube up to the top and could still see the dot a bit. We have had a lot of rain (thus a lot of draining) this year. Initially I was thrilled with it as I had the opposite problem with really high CYA. In any case, I'm happy to be "adding" rather than draining.
    tim5055,
    Yes, I have read the ABC's and have the test kit. I'm totally fine with the kit, EXCEPT the CYA test, which I don't like because numbers is more to my liking. Guess I don't trust myself on seeing the blasted dot.
    Quote Originally Posted by tim5055 View Post
    Aug 2014
    Shallotte, NC
    693
    Re: Raise CYA
    In my experience, it may take up to a week for CYA to show up on the test. Then too, if you squished the sock into the skimmer, most of your CYA is probably in the filter, so don't backwash or you'll lose what is in there. Addition of solid CYA tends to be a character builder......
    Jun 2014
    15,103
    Re: Raise CYA
    Oh yeah, we're just about neighbors really. I'm just on the other side of town. Chilly today. Cooler water temps mean easier pool maintenance - for now. Good that you are testing on your own as opposed to relying on the local pool store. Make sure to ask any questions you have as the season approaches. Stay warm!
