OK, I ran a full test today just to get a feel of the big picture. We have had a lot of rain and I wanted to see where I stand
Note: I have been away all week and my wife has been testing and maintaining Shock FC. Her desire to be confident led to multiple FC tests and running us nearly out of the FC Reagents. Ordered more reagent & instructed her to stop testing and add bleach at the sme dailly rate (abour 96 oz of 8.25% daily. Haven't tested FC in the past couple of days, used the last of the reagents this morning. Expect replenishment delivery on Mon or Tues.
This morning's test results
FC 35
CC 1
TC 36
CH 175
TA 90
PH 8.2+
CYA 55
Looks like the rain water and constant draining to keep the level has helped me reduce the CYA to a more desireable level. Pushing my shock FC level from 28 to 24.
AS stated earlier, I brushed with a wire bush last night because I am still able to rub granules off the pool wall with my hand and do not think the nylon brush is getting the stuff off. After a quick scrub with the wire brush the pool cloued and som white particles are floating on the surface. The filter is now plugging every hour or so with the same brown sandy like substance that i can rub off the pool walls with my hand. I tested some of this that came out of the filter with muriatic acid and get no foaming. At this point I suspect that this is calcium silicate scale that developed over years of neglect.
The photo of the concrete pad & grass shows what has been coming out of the filter.
I know that shock level FC increases PH renders the PH test innaccurate but should I take some steps to lower the PH?
I will remove and clean the light as soon as I finish watching UK beat South Carolina
