Results 1 to 10 of 10
Thread: Need help with Wet Edge finish
    Jan 2016
    Sonora, California
    147
    My wife and I are going back and forth between the Luna Quartz and the Pearl or Satin Matrix finishes for our pool/spa build. Our concern is roughness, is the Quartz a smoother finish than the Pearl or Satin? Thanks!
    Oct 2015
    humble texas
    132
    Re: Need help with Wet Edge finish
    Quote Originally Posted by Eyetattoo View Post
    I would think Satin Matrix would be fine. However, I'm not to sure I would get a WetEdge pool. I am building one and had a lot of issues with customer service. I had an issue with my pb over having the WetEdge name on my contract it was missing. I wanted information as it pertains to warranty and how do I make sure it's the right pool.
    They were extremely unhelpful or offenceful even though per my explanation our goals were the same.
    That said if you have a little more money go prism matrix. However maybe avoid them all together. The other plaster companies may be equally as shady.
    30,419
    A disagreement or misunderstanding with your PB should have no reflection on WetEdge.
    The quality of the product and your clash with the PB over it are really unrelated.
    That said, I have no opinion good or bad on a Wetedge finish.
    Jan 2016
    Sonora, California
    147
    Anyone have additional input? Thanks.
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Can you see if you PB will let you visit any of his former pools for you to see and feel these surfaces in person?
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Sep 2012
    Phoenix, AZ
    87
    If you want completely smooth and don't want to go with quartz, take a look at Wet Edge Primera Stone. It has aggregate, glass beads, etc. incorporated into the mix, but after it's applied it's polished smooth. My PB has it in his pool and he had me go look at it, and it really is gorgeous....and very smooth. I was going to go with Stonescapes, but now I'm looking at Prism Matrix. This is such a tough decision! Good luck.
    My renovation completed March 2016; 16 x 32 IG gunite play pool, ~14,000 gallons; Wet Edge Prism Matrix Indigo Blue; Pentair 5G Color LED Light w/controller; Hayward EcoStar SP3400VSP VSP; Hayward SwimClear C5030 cartridge filter; Hayward Swimpure Plus (Aqua Rite) salt chlorinator system with T-15 cell; Maytronics Dolphin Deluxe 4 DX4 robot cleaner.
    Jan 2016
    Sonora, California
    147
    I like the Primera Stone but with the size of pool (22x42) the cost is a major upgrade. The Quartz would be a $5k upgrade over plaster and the Satin or Pearl is a $10k upgrade.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quartz will be smoother than any pebble. Even the fine grain ones you mention.
    Essential Links:
    Jan 2016
    Sonora, California
    147
    Quote Originally Posted by Patrick_B View Post
    That's kind of what I thought, I'm wondering if there will be a big issue of color consistency with the quartz?
    Under Construction - Free form in-ground pool/spa, 24x42, 815 sq ft, 119' perimeter, 3.5-8 ft depth, 26,500 gallons, Triton II sand filter, IntelliChlor SWG, 3 Intellibrite LED lights, IntelliFlo VS pump, Easy Touch Control System, raised planter box & patio space TBD........
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    Not with a good plaster crew.
