Thread: Can you use a vinyl cleaner on a concrete pool?
    Sep 2015
    Orlando, FL
    22
    Like the subject says, I was just given a Hayward Navigator, but it it a vinyl model and I have a plaster (diamond brite) pool. Can I use it? I tried searching, but didn't turn up much information...
    8200g IG, Diamond Brite Plaster, Hayward Cartridge Filter, Pentair Pump, TF-100, Rainbow 320 Inline Tab Chlorinator [not used]
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,565
    Re: Can you use a vinyl cleaner on a concrete pool?
    I would worry more about using the plaster cleaner in a vinyl pool than the other way. I don't know but the plaster cleaner might have "rougher" brushes than then vinyl.
    This is all guessing on my part. You could call the company that makes the cleaner and ask them what the difference is.
    Kim
    Sep 2015
    Orlando, FL
    22
    Thanks Kim, why didn't I think of that?
    I called Hayward, the only difference is the shoe. You can swap the vinyl shoe for a plaster shoe. Also, it is safe to use the vinyl shoe, but it will wear out faster.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I've had both (still have the vinyl one) and yes just the shoe is the different.
    The vinyl shoes are cork.
    You can find them on amazon if you want to switch to the nylon shoes for plaster.
    Dolphin E10 Cleaning Robot.
