- May 23, 2015
- 24,477
- Plaster
- Pentair Intellichlor IC-60
You can probably measure the CYA now. That particular test is not terribly affect by high FC. The pH test is not as accurate above 10ppm and should never be performed above 20ppm. The indicator dyes for TA and CH can be affected by high chlorine by mostly not showing the right color transition so it's best to wait on those too.
Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
