Thread: Chlorine is necessary or not
    Dec 2015
    Largo, Florida, USA
    13
    Is it necessary to put chlorine in spa for purification of water if yes then how much? What are the main benefits of it?
    30,421
    Re: Chlorine is necessary or not
    read "The ABC's of Pool Water Chemistry" up in Pool School
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I have been using the following process for over two years to maintain my hot tub and it works great.
    How do I use Chlorine in my Spa (or pool)?
    Aug 2014
    Shallotte, NC
    693
    Brenda, it is necessary to put a SANITIZER in your spa. While there are several options for a sanitizer, we tend to recommend chlorine. A sanitizer kills the cooties inevitably introduced with the use of a spa. We couldn't possibly recommend how much, until we know more about your spa. As Duraleigh notes, time spent in Pool School is time well spent....
    Oct 2015
    Austin, TX
    83
    Do you have a spa that's connected to the pool? If it's connected to the pool, use the same sanitation that you use in the pool.
    If it's a standalone spa, you have a few more options. I use bromine in mine. How do I use Bromine in my spa (or pool)?)
    Here's a discussion on chlorine vs bromine: New Hot Tub - Bromine or Chlorine
    Marc
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    This thread is closed. They were a sneaky spammer!
