I am looking for a way to get travertine for my deck and pool build. I believe I found some for a good price. I'm hoping my PB will be ok with working with me on this tile. It's $2.79/sq ft for 12x12 tumbled travertine.
Am I correct in thinking this is a good price?
What's a typical cost per sq ft for install including the installation materials?
Is the installation done with mastic and grouted joints, or a sand bed and a polymer type sanded joint?
Also, tumbled is what you want for decking and coping, right? I'm thinking honed and filled would be slick.
What application would you use honed and filled?
If I go with 12x12 on the deck, what size is used for coping typically?
When you used travertine for the deck, what did you put on your spa? Your firepit? Any pedestals/columns?
Thank you for you input and advice!
pictures of your travertine, including type and color would be welcomed and appreciated!
