Results 1 to 18 of 18
Thread: Pool in NorCal - IG Gunite 30 x 17
    Sep 2015
    Roseville, Ca
    16
    here is what I have accomplished so far,....
    your thoughts or suggestions are appreciated.
    TomCa - IG, gunite, Freeform, 30 x 17, raised beam wall w/ledgestone and flagstone cap, 3ft spill, radiant fusion blue frost, 480sqft concrete decking. SWG filtration, 2 returns, 1 skimmer. 2" & 2.5"PVC . JEP15 Jandy ePump 1.5hp Variable Speed, AquaLink PDA P4 Pool Control , SAVI-MELODY100-J Nexxus 14W 12V Pool Light X 2, J Series, Polaris - 360 Cleaner, Model F1B.
    Sep 2015
    Roseville, Ca
    16
    Re: Pool in NorCal - IG Gunite 30 x 17
    part two:
    Attachment 44189
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Looking good Tom,
    keep us posted!
    Divin Dave,
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    That is quite a bit done already! What is next and when?
    Kim
    Aug 2014
    Houston tx
    2,525
    I noticed in your details you only have 1 skimmer. Is that what your PB recommended? I thought 2 was pretty standard.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Casey's Avatar
    SW PA
    10,453
    Very nice looking pool. Cant wait to see more pics.
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Looks great so far!!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Sep 2015
    Roseville, Ca
    16
    I wanted two skimmers and 3 returns. He talked me down. He stated that for
    a pool my size, that it just wasn't necessary.
    I also wanted all 2.5 pvc piping.
    He stated that for some areas they would use but for others areas, it did not make sense.
    I caved,...
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Hey Tom!
    I saw that you are using Radiant Fusion. We are as well. Would love to see pictures of your finished plaster with and without water. I'm still trying to decide on color. Thank you!
    Denise-TFP Guide
    Casey's Avatar
    SW PA
    10,453
    Any updates?
    Sep 2015
    Roseville, Ca
    16
    Quote Originally Posted by Nursenini View Post
    Hey Tom!
    We are due to apply interior finish after new year.
    I will definitely post a picture. We narrowed it down to Blue Frost or Regal Blue and
    ultimately picked Blue Frost. PB think Radiant Fusion is a quality finish- I could have picked almost any
    finish as an upgrade but liked this combination for alleged quality, longevity, visually pleasing and smooth on the feet.
    Hope it works out,...
    Thanks
    Tom
    can someone comment on this - did I do the right thing in going with 1 skimmer and 2 returns?
    thanks
    Quote Originally Posted by TomCa View Post
    I caved,...
    pending Interior Finish -
    Jul 2012
    Tallahassee, FL
    30,585
    I have one skimmer and one return and make it work for me. You can move the return eyeballs to control the flow of the water. Use a ping pong ball to watch for any "dead" spot in your pool. If you find any dead spots make sure to give them extra brushing.
    Here is a link for you.
    I would add in more brushing but that is me.
    Kim
    Sep 2015
    Roseville, Ca
    16
    Here is pool with Radiant Fusion Blue Frost applied,
    it is with water. We are pleased.
    The weather is gray and rainy but it looks like we will
    get the Caribbean/Turquoise look we were hoping for.
    Tom
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    That is really pretty! Really refreshing looking. No wonder you are pleased!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Turned out REALLY pretty!
    Denise-TFP Guide
    Jul 2012
    Tallahassee, FL
    30,585
    THAT is BLUE!
    Kim
    Jul 2016
    roseville,ca
    1
    Hi! new to the forum, just moved to Roseville. Did you hire a PB or did you GC your own pool? looks great!!
    Sep 2015
    Roseville, Ca
    16
    Hi and good luck
    We went with pool builder. I interviewed 7 pool builders and considered vinyl, fiberglass and gunite. We went with Premier Pools in Sacremento. Tony Estipular was my sales guy and point person. We had a good experience. I was a high maintenance customer and Tony was patient and informative. His response to me on email was great. I also txt'd frequently with Erik V the construction superviser. With any PB, I suggest you be invovled everyday, ask alot of questions, elicit their suggestions and hold them accountable to quality work. They mean well but are forced to move very fast and that can compromise some small detailed stuff. Overall I was pleased with their work. I found Premier to be the most flexible on price and extras.
