Thread: peanut oil in pool
    peanut oil in pool
    So my daughter decided to pour peanut oil into pool...not sure how much, but entire surface has oil spots. What's the best way to remove the oil? do I need to drain?
    20'x42' inground, Stonescape pebble finish, 41K gal, Jandy Stealth 1.5HP SHPF1.5-2 dual speed pump, Tagelus TA-100D sand filter, CircuPool RJ60 SWGS, Polaris PB4-60Q booster pump, CareTaker in-floor cleaner, Polaris 380 cleaner bot, 2xIntermatic 1353 Timers, Sta Rite 400k Natural Gas SR400NA heater
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: peanut oil in pool
    You don't need to drain. If there isn't too much oil, you can use a Scum-Ball. If you have a lot of oil, you can use a PIGŪ Oil-Only Absorbent Mat Pad.
    JoyfulNoise's Avatar
    May 2015
    13,170
    peanut oil in pool
    Quote Originally Posted by chem geek View Post
    You don't need to drain. If there isn't too much oil, you can use a Scum-Ball. If you have a lot of oil, you can use a PIG Oil-Only Absorbent Mat Pad.
    +1 on the Pig Mats!! I've used p/n MAT551 to clean up my sister-in-law's Exxon Valdez-like tanning oil slicks that she leaves in my pool every time they visit. One free floating in the pool and the other in the skimmer. Works like a charm.
    Matt
    Cool, thanks guys. I ordered both! I think i'm going to grab an enzyme from leslie's as well while the pig mat and scum ball are shipping. I also thought to run just the skimmers on waste setting to skim off the top oily water. Good idea?
    May 2015
    13,170
    Quote Originally Posted by quacka View Post
    Unless you have Venturi type skimmer's or the water level in the skimmer is really low, the oil will collect and float in the skimmer and not get flushed to waste. I wouldn't bother with the enzymes but I doubt it will hurt anything.
    Matt
