Thread: Total Alkalinity only goes to yellow
    Sep 2015
    La Porte, Texas
    37
    Using Leslies kit goes to green, but titrates only to yellow (50 drops)
    does that mean TA is really low or very high and I did not hit final titration point?
    FC was 10+ could it be just bleaching the result?
    17' x 35' x 8' in ground Vinyl lined, 24400 gal, age unknown
    Pentair Cartridge Filter
    Hayward Super II Pump
    ( liquid bleach)
    Richard
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Total Alkalinity only goes to yellow
    Yes, at high FC the TA test goes from blue to yellow instead of from green to red. You can add more sodium thiosulfate drops (R-0007) to the initial water sample to neutralize the chlorine. If you can see the transition in color, the test is still valid.
    The TA indicator dye is a mixture of bromocresol green that goes from blue to yellow and methyl red that goes from yellow to red. So when both dyes are active you go from blue+yellow=green to yellow+red=red. High FC levels react with the methyl red dye leaving only the bromocresol green dye that goes from blue to yellow.
