Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: How often do you brush your pool?
    Nov 2014
    Palm Desert, CA
    99
    How often do you brush your pool and run your vacuum? I brush 2-3 times a week and run the vacuum for a few hours almost daily. Not sure if I should be brushing more though.
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,515
    Re: How often do you brush your pool?
    wall brushing is my husband's only pool job. During the summer he does it at least every other day. I run the vacuum as needed if there is stuff for it to pick up or at least once a week.
    Every pool is different with different environmental variables that can cause problems. See what your pool like/needs by testing and looking at the water.
    Kim
    Aug 2014
    Northern IL
    4,615
    I only vacuum when there is visible gunk.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    do the bristles on the vacuum count as brushing
    i really need to brush more often
    probably once a month
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    I don't recall the last time I brushed or vacuumed the pool and it's clean still.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Aug 2014
    Northern IL
    4,615
    I shoot for once a week. I have poor aim.
    Jan 2015
    TX
    49
    1-2 times, every 1-2weeks - depends how much dust stirs up when i brush
    TX/Dallas | 18K ? gal. | Plaster | Jandy valves, Jandy panel, Aqualink RS4
    Pentair Challenger Fixed 2hp | SWG AquaPure PLC1400*repl 2015 | Pentair Clean & Clear 420
    ThePoolCleaner 2wheels
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Brushing weekly is pretty common.
    Aug 2014
    Northern IL
    4,615
    And is recommended!
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    Skippy aims to do it about weekly in the summer. He actually likes to get in the pool and do it from inside
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    I only toss in the vac if i see visible debris. It is not often since I don't have trees dumping garbage into the pool. However, I don't even own brush. I have had my pool for 1.5 seasons, and have not done it once. Maybe I am a disaster waiting to happen. However, I never saw a need to brush them.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    Jan 2012
    7,348
    Quote Originally Posted by yostmatt View Post
    Algae has this ability to coat itself with a protective layer called "biofilm" which protects the algae from the chlorine. When you brush, you're disrupting this biofilm which may be there and yet you haven't detected a problem yet. While the brushing disrupts the biofilm it also helps increase circulation in those areas that are often limited in circulation for whatever reason helps expose those areas to the chlorine.
    So an occasional brushing is a *good thing*
    Yippee
    Aug 2014
    Northern IL
    4,615
    Yes, YipSkip! I may be a bit lax on brushing, but I would never let it go more than 10 days or so! Conventional wisdom is once a week for maintenance.
    yostmatt, you must have an amazing vacuum or dumb luck. Play the lottery!
    Oct 2015
    Burleson, Texas
    178
    Does a robotic cleaner count for brushing?
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    I brushed daily when the plaster was new. Now about once every three months. Love my Polaris!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Killer95Stang's Avatar
    Sunny SoCal
    591
    In the summer I brush once a week and try to manually vacuum once every 1-2 weeks. In between cleanings I throw the MX8 in to take a whirl around the pool. For some reason I have real bad balance and tend to fall in the pool a lot when I'm putting the vacuum hose and poles away.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    domct203's Avatar
    Jun 2015
    CT
    3,587
    I brush whenever I get in the pool (daily in the warm weather), minimum of every other day when not using the pool. I vacuum every 5-7 days, more if there is visable debris in the pool.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Saturn94's Avatar
    Mar 2015
    Virginia
    499
    Polaris 280 runs 3-4 times a week. Manual brushing at opening, closing, and maybe once during the season.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Jun 2013
    South Florida
    118
    Once every 2 weeks or so. I have gotten lazy in the past year or so.
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
  20. Back To Top    #20
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    I brush almost every day. I might miss one but never two in a row. But then, I can brush my whole pool in 15 minutes and do it while standing in the same spot.
    Quote Originally Posted by Killer95Stang View Post
    I certainly hope that was meant to be funny, cuz it was. If it wasn't then I'm appropriately, embarrassed.!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
