Thread: Closing WaterFall Only
    brittonjl's Avatar
    May 2015
    Stanley, NC
    2
    First time pool closing and all I want to close is the waterfall. Do I hookup the air compressor to the pump and turn off all lines but the waterfall? I have 2 drain plugs on the Jandy FHPM pump. Does it matter which one I use?
    12k gallon IG, plaster, CV340 Jandy Filter, June 2015 install, TK100 w/borates, 2ft waterfall
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,245
    Re: Closing WaterFall Only
    Why only close the waterfall and not the whole pool?
    Yes, you can hookup an air compressor to the pump and shut down all the lines (Do not over pressurize the system). Please make sure your filter is on the "recirculate position". You have to isolate the waterfall so only air is pushed through the plumbing for the waterfall.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    brittonjl's Avatar
    May 2015
    Stanley, NC
    2
    I planned to keep pool open through winter since I have a freeze sensor but wanted to clear the waterfall line.
    Catanzaro's Avatar
    Jul 2014
    2,245
    I highly recommend closing the pool. Personally, I would not feel comfortable with any sensor, as they could go bad. Already this weekend, we are heading into the 30's, but not necessarily extended freezing temperatures.
