Thread: What to remove from pool for winterizing
    Aug 2014
    St. Paul Park
    10
    Hi all-
    This is my first winterizing and I thought I read somewhere that you remove the hoses/clamps from the skimmer and the return, but that you could leave them both in place for the winter- just make sure the winter cover is covering them both. Now I can't find that instruction and just want to make sure I understood it correctly.
    I live in Minnesota in case that matters.
    Thanks
    18'x52" Round Might Sun Sierra AGP (bought second-hand March 2015- at 10 years old) 8600 gal; (Crushed limestone covered with 1/2" Foamular bottom and Gorilla pad. Foam walls.) Hayward SwimPro Model SW1750MAR Filter; Hayward 1.5HP EP pump; Perform-Max Model 920 Sanitizer
    Taylor K-2006 Water testing kit. Hayward AquaBug cleaner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: What to remove from pool for winterizing
    Isolated Spa - 345 Gallons
    Aug 2014
    St. Paul Park
    10
    I actually already printed that off and was using that for the closing of the pool, but I didn't see the answer to my question in the winterizing instructions. I just read through it again to see if I missed it, but I'm not seeing the answer to my question there. Sorry-
    I'm specifically wanting to know if I remove the intake and skimmer baskets and leave just open holes or can I leave them attached to my pool and cover with the winter cover.
    Thanks
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Depends on your temperatures.....I used to leave ours in when we had the above ground, but it doesn't freeze here.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Aug 2014
    St. Paul Park
    10
    It does freeze here- Minnesota. I had someone else put both the skimmer and the return on and I'm not sure how to get them off. The skimmer I can figure out, but the return- I'm not sure how to remove it.
