Page 1 of 3 123 LastLast
Results 1 to 20 of 59
Thread: New Build Ontario Canada
    supercanadian's Avatar
    London Ontario Canada
    154
    New Build Thorndale Ontario Canada - Inground Pool
    Hello! I bought a new house and moving next month!
    I am just about to sign a contract with a builder I feel pretty confident in. He has done several of my friends pools, I've called random references and feel pretty confident after getting a few quotes. I am hoping to start this thread for people to offer advice insights and anything that could help me during this process!
    Equipment List:
    16x32 Kidney Crescent
    Hayward Aqua Rite Chlorine Generator
    Hayward Pro Logic Control Center
    Hayward Tristar Vari Flo
    Hayward 24in Sand Filter 2in head
    Hayward Colour Logic LED
    Hayward 250,000 BTU Millivolt
    8’ft stairs (colour TBD)
    Coping Concrete Cantilever
    Here is a rough sketch of the layout of the pool, and a few pictures of my yard which as you can see slopes pretty significantly which requires a retaining wall.
    16x32 Kidney Hayward Aqua Rite Salt Generator, Omnilogic, Tristar Vari Flo Sand Filter, Colour Logic LED, WFSD Waterfall, 250 BTU Millivolt, GVA-24 Valve Actuator TF-100 Test Kit
    Pool 1
    Pool 2
    my build
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Re: New Build Ontario Canada
    That's going to an awesome backyard oasis for you! It's a vinyl liner pool, right?
    Keep us posted on your progress. And good luck from a fellow Canadian (transplanted to TX)!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    154
    Vinyl liner for sure. Very excited as we get the keys end of October and the build should be in the May. I have to have a septic tank removed and conversion to city water before it can be done which will be done the week I get the keys.
    Pool 1
    Pool 2
    my build
    154
    Just an update....
    Builder was out yesterday to show me on the ground where the pool would sit so I can determine my decking. Also I am undecided if I will do a retaining wall or slope it off the back. The builder said he can do either as I have such a sloped yard I need it either way. Any ideas what is the better option? I think the retaining wall would look better and let me lose less yard to the hill that will be needed to grade it down.
    Pool 1
    Pool 2
    my build
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    I'd recommend that if you are going to have a sidewalk/decking on the far side, that you go with a retaining wall. Reason being that it will be easier/more effective to properly compact the subsurface for decking between the pool shell and wall versus the pool shell and nothing. It can be done but is more likely to settle. And if your goal is to retain maximum usable yard space below, the wall is your friend. Though not that of your wallet/budget.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Our pool is our retaining wall, it is about 18" out of the ground, faced with flagstone with 12" wide coping and no deck on the part out of the ground. We love it and it has worked out great. Pics in my build thread, link in sig.
    Aug 2014
    Northern IL
    4,615
    Either way will be great!!!! I am a bit worried about drainage, but the pics may be misleading. Does your lawn slope inwards towards the pool from those other three sides? Vinyl liners loathe drainage issues.
    Jan 2015
    Maritimes
    56
    Swap out the sand filter for a 425 sq ft cartridge filter. Ensure the SWG is a t-cell 15
    Reasoning for swapping out sand filter is a lot of communities in Ontario now make it illegal to dump salt water into municipal. The cartridge can be cleaned easier and with less waste. It will also filter better.
    I think the P4 controller is overkill.
    154
    Quote Originally Posted by Pooldoctor View Post
    Thanks for the insights! I will read into the cartridge vs sand filter to see. I don't know much about the p4 controller or setup but I know I don't need much to control it. Your correct in my area you can't dump pool water unless it is a below a certain chlorine limit.
    Pool 1
    Pool 2
    my build
    Nov 2015
    Kelowna
    1
    A few thoughts...
    1. Completely agree with the recommendation regarding switching to a cartridge filter. Although they are indeed notably more expensive, they negate the need for backwashing and the continuous replacement of salt. Not to mention they are offer far greater flow restriction and filter cleaning is a fairly simply process.
    2. You mentioned that you will be receiving an AquaRite and a Prologic board. The AquaRite generator is unnecessary in this application considering you can plug the TurboCell directly into the ProLogic (P4) board and control it from there. I also highly recommend the installation of a sacrificial anode (zinc) in the pool plumbing and a check valve between the heater and salt cell. Also ensure the install the cell with 12" of straight pipe before the flow switch.
    3. While this is strictly my own opinion, consider replacing the Universal Millivolt heater with a Universal H-Series FD. The Millivolt version is a reliable model, however it utilizes a standing pilot light (which can and will be extinguished in windy areas) and cannot be controlled off of your ProLogic panel. If you are spending the money on a relatively expensive automation board, you want to control as much as possible as easily as possible. Also, consider downgrading the size to a 200 btu. The heat loss of a swimming pool is based off the surface area of the pool and considering the size of your pool, a 200 btu will suffice more than adequately.
    154
    I am getting close to signing my final contact and have already put down a deposit to hold my build for late april and early may. What is a typical payment schedule? My builder said 40 at signing, 50 at the first dig and 10 once complete. Is that fair? I was thinking 40/40/20. He said if i wanted to do 20 at the completion he is fine with that.
    Pool 1
    Pool 2
    my build
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    I think even a 10% holdback is ambitious these days, sadly.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Aug 2014
    Houston tx
    2,524
    We didn't have to put anything down at signing.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Oct 2015
    Katy/Texas
    411
    I would check around and see if builders wanting a large down payment when you sign the contract is normal in y our area. Personally I would not give any money until the work has started and then pay amounts that are proportionate to the labor and materials completed.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Aug 2014
    Northern IL
    4,615
    Our local PB requires at least something down to put you in their queue, even if it's just a minor issue. They're busy.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    40/40/20 is SO much better if you can do it. His willingness to do that speaks well for more than one reason. If you can do that always do it without fail. I would drop any builder who insisted on less than 10 like a hot potato. The more you have on the back end, the better off you are.
    Essential Links:
    154
    Quote Originally Posted by supercanadian View Post
    Just an update....
    So i sold all this rock and now it looks like this. I sign my contact tomorrow. I feel broke!
    Also had to convert to sewer system this week which involved breaking up my basement floor in my cold room and then draining my septic tank to get ready to be pulled out of the ground. You can see the outline of where the tank is the weeping bed in the grass.
    Pool 1
    Pool 2
    my build
    Jan 2016
    Mesa, Az
    541
    That picture creeped me out. I kept wondering how I was seeing a foot on your patio. Then I realized it was your reflection in the glass!!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,490
    I would do the wall. The yard up keep will be easier also. Just think of having to mow the slope.....no thanks! LOL
    That is a lot of prep work already!
    Kim
  20. Back To Top    #20
    Mar 2016
    Ontario
    3
    Quoted a few builders in ontario myself this year and 40% down seems pretty steep. Most quotes i got were 20% deposit.
    See if you can get ecostar pump, compared to tristar it was only 100 more and i believe it is a better pump.
    Also check pricing on stone coping. Most of the builders i quoted did concrete cantilever coping at a fairly high price so upgrading to stone coping was actually not a big price jump and it will hold up better over time.
    With concrete decking that goes past the 3 foot xframe support of the pool i was told that it is an area that will develop a crack as it will be spanning two different foundations that move independently. See if your builder has ideas on mitigating that.
