Thread: Diverter valves on returns
    Oct 2015
    Brookside Village/Texas
    3
    I am in the process of having my pool replumbed. Is there a benefit to diverter valves on my returns if I do not have any water features or a spa? I will have diverter valves on each suction line.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Diverter valves on returns
    I am a believer that all plumbing lines should have a valve or diverter. This is especially true if the equipment pad is a a lower level than the pool.
    You may never need the valves, but if you do teh extra few dollars up front will be less expensive and much less hassle than adding them later.
    Support the site
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Personally, I wish my returns had at least a 3-way valve between the two separate lines. I only have 2 lines at the pad, but 3 returns. It would be very nice to be able to balance the flow or turn off one or the other during closing etc. I'd say at a minimum, I'd go for 2 common lines that each split to 2 returns at the pad with a 3-way valve between the common lines. To go further, you could have a 3-way valve linked to 2 downstream 3-way valves that feed the 4 return lines. You could also go with four 2-way valves, one for each line.
    Isolated Spa - 345 Gallons
