Results 1 to 10 of 10
Thread: Spa jets are weak.
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    Spa jets are weak.
    How do I get my spa jets to strengthen without using air that is splashing water out n us over our heads? I got smaller jet covers n blocked one. There are 6 jets.
    Jun 2015
    Wildomar, California
    423
    Re: Spa jets are weak.
    Off the cuff, either smaller jet nozzles or a bigger pump. More info or pics would help our diagnosis.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    I can't explain this, but my spa also has weak jets, until I turn on the air and let it run a few minutes and the flow from the jets strengthen dramatically. If I then turn off the air, the jets remain strong. Wish I understood why?
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Because the blower is mainly for clearing the air pipe of water. Once the pipe is cleared of water, the venturi's can operate properly and keep the air pipe clear on their own. Nearly any spa can be built without the use of blowers but many PBs use them as a crutch because they don't know how to build a spa without a blower.
    Mark
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    What can I tell my Pb to fix about it?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Usually, the simplest solution is to replace the jet nozzles with a smaller version. This increases the water velocity and makes the jet feel stronger. But it may or may not be possible depending the jet design.
    Mark
    Oct 2015
    AZ
    30
    are they open all the way, are they adjustable by spinning the outer ring. my new spa last year, i got in and thought some of the jets were broken, turns out they were not open all the way
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    Is yours a stand alone spa? Mine is connected to the pool plumbing. I just had the plumber out n nothing wrong or that he can do. So I blocked 2 of the 6 jets, Used smallest holes in jet cover on 2 for foot massage, n 2 med holed ones for back massage. Pressure has gone up to half of that with air. Livable pressure.
    Oct 2015
    AZ
    30
    yeah, mine is cal spa standalone.
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    Standalones are better for therapy n stronger I've noticed.
    18000 gal 9ft, swg, ig, dk blue plaster( Montego Bay), cartridge filter, attached spa, build finished September 1 2015, Pentair equipment and Legend creepy. Natural stone with salt for the -ions n health benefits. Worth it to me.
