Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Torrential Rains in SC overflowed my pool
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    So I had my level down low in preparation for some serious rain but I wasn't prepared for the road behind me to overflow into the neighbors yard and wash down into my pool )c:
    How much of the pool am I going to have to drain to get it back to where I can get the chems correct?
    https://youtu.be/HStAARMvSbU
    Clint
    Pics of the build process
    34x16x25 Lagoon IG Vinyl 14,800gal (Oxford Tile/Glimmerglass 20mil)
    Pentair: Intelliflo VS3050 pump, Intellichlor IC40 SWG, Clean and Clear 320 cartridge filter, LA01N 3/4hp booster pump and Polaris 280 cleaner
    Jun 2014
    15,212
    Re: Torrential Rains in SC overflowed my pool
    Uhg. Joaquin was not very nice to you. If your pool does not have overflow relief, you'll have to drain on your own back to your normal water level - probably somewhere with the waterline halfway to 3/4 up the skimmer opening. From there, all you can do is manually remove any debris that may have gone in the pool (that you can see), then check your chemicals by testing with your kit. Adjust as necessary. You will probably need to implement a SLAM as your pool will be struggling with a high combined chlorine level if some contaminants flowed-in the pool. You have the option to drain more water to help clear it faster, but you won't be able to drain it all. In fact, I suspect the higher water table in your area may prevent you from going too low right now, so I'd be very careful about how much you drain. I suspect time, good filtering (cleaning), and chemical adjustments will be the course of action for a while. Eventually a lot of the muck and dirt should settle allowing you to vacuum it better as well. Thanks for posting the video.
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    thanks so much. I was hoping that was the answer. Much more work, but better that way. I have the vac hose in and am siphoning it down now but we have 4 more hours of torrential rains they say
    Clint
    Jun 2014
    15,212
    Sorry about your troubles. I'm sure (in time) it will all settle and you'll have that water crystal clear again. Just takes time. Stay safe.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,584
    TS has you covered. I just wanted to jump in and give you a hug
    Time, filter, bleach, beer will all work together to get your pool back to clear.
    Is this the first time this has happened? I wonder about running a raised wall along that part of your yard in the future to push the water away from the pool. Use the video to show you where the water went and how to redirect.
    I am looking at your build now. NEAT stuff!
    Kim
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    Beer may not cut this, may need copious amount of hard liquor LOL
    Clint
    Jun 2014
    15,212
    Aug 2014
    Northern IL
    4,615
    Be careful about draining too much as the water begins to recede. When you can start to drain, I would suggest only going right below where your liner goes into the coping. There will still be a lot of pressure from ground water so you want your pool as full as it can be without letting it creep behind the liner at the coping. You don't want your liner to float.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Just wanted to pass on good wishes for you and your neighbors.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    oh my...
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Jul 2014
    Hope Mills, NC
    567
    Quote Originally Posted by kimkats View Post
    This was a 1000 year storm, "in the future" may be several hundred years away. I wouldn't worry too much about it happening again.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    Some advice please, Lets presume the pool has dirt and debris in the bottom from the rain runoff.
    I have a cartridge filter and a pumpside polaris.
    I ran the polaris for five minutes and the bag filled up.
    I am going to start scraping the bottom with the net.
    Should I run the pump? I know I will have to be cleaning the strainer basket pretty often if I do
    Clint
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Best of luck to you, awarsoca, you sure got a huge amount of rain!!
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Jul 2012
    Tallahassee, FL
    30,584
    Is there any way you can get your hands on a cheap sub pump to pump the gunk out??? May be worth it to buy a cheap harbor freight one.
    Kim
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Awasoca, I second the trash pump to help clean it with one caveat....you will need to add water as fast as you pump it out, because with the water table so high, you don't want to risk the liner.
    So you might be a candidate for "the sheet method" -- which is the safe way to change water in a vinyl liner. Dct Tape together visqueen plastic you can get at home depot, lay it on top of pool (with extra on sides for ultimate depth), add the fresh water on top of it while using trash pump below to get rid of the sludge.
    You'll still have to slam, but it will be easier once you get the mud out
    Depending on how much storm sludge is in there, you could clog your lines just filtering...in which case (if you're doing it) get a drain snake that works with a hose in case you have to clear the lines.
    When I recovered a foreclosure swamp, I'd kept main drain 3/4 closed in beginning to help avoid clogs until I'd gotten much of the debris out. I DIDN'T use a trash pump cause I didn't know about sheet method...but would never go that route again knowing what I now know
    Sendin ya the light for a smooth recovery!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    P.s. if the soil is uber fine in your area, this may also at a later stage of remedy be a case (they're rare) to actually use Alum floc to clot the fine particles together and let them drop, then vacuum to waste. But that ay be more of a "finishing" step right before Slam to reduce whatever particulate is left -- I wouldn't count on it working with your current load and turbidity.
    pPS - I'm sending you imaginary 18 year old scotch, because I don't think beer's gonna cut this one
    Helpful Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    I dont think this will be as bad as you might imagine. More than anything, its mostly just dirt and mud.
    When it stops raining, turn off the pump and let the suspended dirt in the water settle to the bottom for a day or 2, then vacuum to waste. LIkely that you'll have to repeat the process a time or 2 before letting your filter get the last bit.
    When you're to the point for the filter to take over, then test to see if you need to slam or not, and go from there.
    Divin Dave,
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    Update!
    I dragged the bottom with the scoop net and managed to get a bunch of debris out. Mostly leaves and straw. After lots of Rum, I decided to turn on the pump. I run a cartridge filter. After a couple hours, I realized I was losing the flow. I popped the cartridges out and between summer swim season and the dirt, they were filthy. I put my spare set in and the water was flowing great. This morning I still have excellent flow and can just see to the bottom of the shallow end. I've got the first set of cartridges clean and will swap out as the flow dictates.
    Looking forward to being able to clearly see the shallow end to clean it and ultimately the deep end
    Clint
    Aug 2014
    Northern IL
    4,615
    How does your liner look so far?
  20. Back To Top    #20
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    scattered leaves in shallow end, silt on stairs and ladder. Bout as much as I can tell at the moment
    Clint
