Results 1 to 8 of 8
Thread: bio active
    Dec 2013
    San Antonio, TX
    38
    bio active
    Has anyone used this product? If so any success? How long should I wait to test cya after use of this product?
    San Antonio TX 14K Gal in ground free form jandy vs pump with DE filter polaris cleaning system with auto feed chlorinater, JandyJXi400N natural gas heater
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: bio active
    Several people have posted about it. A search will find them. Little success.
    JoyfulNoise's Avatar
    May 2015
    13,201
    Re: bio active
    Unfortunately no consistent good results. Only a few spotty claims that it lowered CYA a little, the majority of trials reported here were complete failures.
    Matt
    Feb 2012
    Phoenix, AZ
    728
    Re: bio active
    Seems like success has been 50/50...here are a few reviews I have seen:
    Good Review:
    "My cya level was so high that I had to use this product 3 times. It brought the cya level down a little each time until finally it was below 100. Apparently for best results you need to make sure your ph and chlorine are in balance and one treatment will lower the cya up to 150. I have an above ground pool and could not drain it so this was the only choice I had. It did what it was supposed to do. I am satisfied."
    Bad Review:
    "This product was a waste of money, I did everything per instructions and this product did not produce results as advertised. After waiting to to see results, I ended up draining the pool a third of the way and refilled in order to lower the cyanuric acid level. My cyanuric acid level was at 100 in the beginning and after using this product, it lowered only by 10 down to 90 which might actually have happened due to removing the use of chlorine and relying on shock without stabilizer not this falsely
    advertised product.
    It's very important to follow the instructions exactly if you do want to see good results, but even then have heard some feedback of it still not working well. The manufacturer says to wait up to 10 days to allow the product to work. If your fed up with draining and replacing your water, might be worth a shot.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: bio active
    If you have to drain it will be only once. Once you start using the TFPC method, you never have to do that again. Good bye Pool $tore, Hello self maintenance.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2015
    13,201
    Re: bio active
    Quote Originally Posted by blakej View Post
    Good Review:
    Bad Review:
    advertised product.
    Are those TFP reviews or some other source? Most of the TFP threads I have read this season were failures. TFP member Aqua Lab Rat even did extensive testing in this thread and could get no measurable difference or positive results.
    It would be nice if the stuff worked but, so far, it seems to be a dud.
    Matt
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: bio active
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: bio active
    Amazon still shows mixed results and those results may not all be legit. Same with Leslie's and Pool Supply World.
