Results 1 to 11 of 11
Thread: Stenner pumps and acid
    Mar 2015
    Dallas, Texas
    133
    Can stenner pumps be used for acid additions?
    Build in progress: 31x18 GI (17,336 gallons) / Diamond Brite French Gray finish / Flagstone Coping / 30ft weeping wall with 7 stations plumbed / Salt Finish Deck / Pentair EasyTouch Controls / Pentair IntelliFlo Variable Speed Pump / Pentair D.E. Filter 60sft / Polaris Automatic Pool Sweep w/ Booster Pump.
    22,553
    Re: Stenner pumps and acid
    They sure can. All the wetted parts are compatible with muriatic acid. It's recommended to dilute the acid, but not absolutely required.
    Mar 2015
    Dallas, Texas
    133
    Ok awesome. Also anyone know if you can wire the stenner to a pentair easy touch panel as an aux feature...similar to the pool lights ect?
    JoyfulNoise's Avatar
    May 2015
    13,254
    If you have a spare relay, I don't see why not. The Stenner's are typically controlled by a standard 120V timer switch. The EasyTouch relays would be similar.
    One suggestion - mount the pump away from the acid container. The biggest downfall of some of the commercially available systems like Pentair's IntelliPH is that the pumps are located right above the chemical tanks. The acid vapors eventually rot away the motor components leaving the user to have to buy spares.
    Matt
    Mar 2015
    Sugar Land , TX
    424
    Quote Originally Posted by daveooph View Post
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    That is exactly what I did. I have a ET 8 and the far right relay was not used. I wired a plug to that and plugged my Stenner into the plug ( to save warranty on Stenner ). I use the last button on my wireless to control Stenner manually if I want. I have it programmed into ET8 to come on when pump is on.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Jan 2016
    Pearland, Texas
    12
    Hello, pool newbie here. I am seriously considering a Stenner since my chlorinator does not work at low speed with my Intelliflo. Need to wire it to my Pentair EZ Touch 8. Can anyone give some tips? Would be appreciated.
    Finished December 5, 2015. 26,000 gals IG pool w/ 7 ft. dia. Spa, WetEdge Plaster, Intelliflo VS main pump, Whisperflo pump for 5 Scuppers. Cleaner booster pump, Pentair EasyTouch 8 panel, Rainbow 320 chlorinator, FNS 60 DE filter, Pentair Racer, 3 Intellibrite LED's, StaRite Max-e-Therm 400k heater, Stenner chlorine metering pump, FloVis flow meter.
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    I know the Stenner chemical storage tanks are vapor free - well designed to preclude escaping acid vapors. Is this not the case with Pentair's storage tanks....would be ill designed IMO if acid vapors are allowed to escape the tank.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    May 2015
    13,254
    Quote Originally Posted by Jaimslaw View Post
    If you search the threads on IntelliPH, you find plenty of examples of folks complaining about the short motor life. Even the Pentair manuals state that motor lifetimes are only a year. The problem with the IntelliPH design is that the motor is mounted onto the tank. So there's no way one can add acid to the tank without vapors hitting the motor. The tank itself may be well-sealed but it's simply where the motor is mounted that is the problem. It would be far better to have the tank and motor spatially separated by a good distance so that vapors are less likely to contact anything critical. Using diluted MA (15% strength) seems to also help reduce wear & tear. It's probably even advisable to drain the tank of acid in the off season since most people use a lot less MA when the weather gets cold.
    Matt
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    I did read about those acid corroision issues with the InteilliPH pump - something that I do not see ever happening with the Stenner combo tank/pump set up given that the fill lid on the Stenner tank is to the right of the pump housing (i.e. out a harms way from vapors during the flll process). Somewhat surprised that this built in obsolesence on Pentair's part has not beenr rectified.
    May 2015
    13,254
    From the IntelliPH Operation & Installation Manual -
    Working with muriatic acid can be dangerous. When cleaning the IECG always wear rubber gloves and eye protection. Always add acid to water, do not add water to acid. Always work in a well-ventilated area. Splashing or spilling acid can cause severe personal injury and/or property damage. Pentair always recommends 1:1 dilution when using full strength muriatic acid. When mixing, remember to always add acid to water.
    Also this -
    IMPORTANT! Replace the IntellipH pump head tube (P/N 522480) once a season (yearly). For units built before 8/2014, replace the whole pump head (P/N 521514) every season.
    So on older units, the entire pump head (not motor drive, just the head) had to be replaced. Newer units just use a replaceable tube much like Stenner pumps. Tubes are cheap, pump heads are not. So it looks like they wised up a bit when people complained about the excessive annual costs. However, note that they "recommend" you use a 1:1 acid dilution which is essentially the same as using 10 Baume (15%) MA. 10 Baume MA barely produces any fumes which makes it a lot easier to pour and work with but you will definitely be refilling the tank more frequently.
    Matt
    May 2011
    Granite Bay, CA (Sacramento area)
    99
    Question about adding diluted acid to the storage container- when adding water and acid while there is still some diluted acid in the container, is it better to:
    -add water first (adding water to acid is not good) then the acid?
    -add the acid first, then the water (again, adding water to acid- no bueno)?
    -dilute the acid in a different container, then try to pour that into the first container (can't see how to do that without getting acid all over my pool equipment)?
    18,000 gallon IG gunite freeform pool
    Intelliflo VS pump; Hayward SwimClear-C4030 425 sq ft filter; 4x suction PoolCleaner
