This morning the hot tub was totally empty. Picked up a new check valve but old one doesn't look broken. Automated pool. Pool came with house not 2 years old yet. What else can be the problem? Pent air system.
Is it a pool and spa combo? I would suggest you look at the possibility that your system has valve actuators and your system ran on spa suction and drained your spa. Check the micro switch on your suction valve or that it was put into spa suction mode
This happened twice to my brother in law. The first time the Easytouch system went into drain mode for some reason, and the 2nd time the valve actuator broke on the suction side and was stuck with the spa drain on and pool returns. Pool is about 2 years old.
