Thread: SWG and algae
    Sep 2015
    Sammamish
    8
    SWG and algae
    Hi...thrilled with our SWG but lots of algae in pool near the end of summer (now)
    Have drained pool and wondering if ok to let the pool completely dry and trust/hope
    that the algae will be easy to clean when we put it up next summer or if suggestions
    for getting rid of it now while dry? I am trying to stay away from chemicals/bleach etc
    so lots of the (good) suggestions on the main Algae forum thread (...shocking pool
    next summer etc) don't really apply to our situation. I'm thinking if the pool is dry and
    sits in garage all winter perhaps the algae will just flake off easily with vinegar/bake soda
    next summer? Any damage potentially to vinyl by leaving the algae in pool all winter?
    thanks so much!
    38,319
    Re: SWG and algae
    You realize that the SWG is putting chlorine in the water right? So I do not understand your restrictions.
    Aug 2015
    Montreal, Quebec, Canada
    36
    Re: SWG and algae
    Quote Originally Posted by DeniseD View Post
    thanks so much!
    Hi Denise,
    A SWG alone will not get the job done in order to sanitize the pool properly and kill all the algae and bacteria. Seeing that you already have a bunch of algae, your SWG is not giving you the proper FC for kill everything off.
    I would have suggested to SLAM the pool but seeing as you are taking the pool down, I would suggest some reading to prepare for next year.
    The key to a trouble free pool is knowing what is inside your pool and its chemical balance.
    Pool School - What is TFPC?
    Pool school will help a lot with this. Pool School - Pool School Index
    As jblizzle says, the SWG converts the salt into chlorine. So your "chemical" restriction is not really practical.
    By not keeping the right chemical balance, you will keep seeing a continual of algae, no matter how high the SWG is set at. Many of the "chemicals" suggested on the site are regular household items that in the proper concentration will not have an adverse affect on the health of your family (which I assume is your concern). But on the contrarty will help kill the bacteria that would otherwise be harmful to your health if not kept in check.
    These links may help clear up some hesitation you may have.
    Starting next year, I suggest you get yourself a proper test Kit, and get to know the inner workings of your pool.
    This link may help you choose the proper kit for your needs.
    Pool School - Test Kits Compared
    These links will be very helpful in managing your SWG pool next year.
    Pool School - Salt Water Chlorine Generators
    Pool School - Water Balance for SWGs
    Pool School - Chlorine / CYA Chart
    As for this winter, since the pool is already drained, i suggest you scrub as much of the algae off as you can, hoping that you get it all and keep it dry for the winter. Im thinking that any residual algae can be slammed properly when you reopen the pool next year.
    44000L oval above ground vinyl pool ---Taylor K-2006----
    Jacuzzi Saniclear 20 salt generator, Waterco XLRU50btu Heat Pump
    Jacuzzi L192 19" sand filter, Jacuzzi 1.5hp pump
    Pool School + Test Kits + PoolMath = Happy Times
    If in doubt SLAM - Shock Level And Maintain + Perform the Overnight FC Loss Test (OCLT)
    30,424
    Re: SWG and algae
    If you fold/roll up the pool now and it's a mess, you will have that mess in the Spring........maybe worse if the algae hardens and sticks stubbornly to the pool.
