Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: First Test Results - Needs some help, please
    Lepidoptera's Avatar
    May 2015
    Toronto/ON
    40
    Actually, these are my third test results for my new pool. I've been posting in another thread but haven't had any responses to my questions there.
    This morning's results using my TF-100:
    FC = 1
    pH= 8.0
    CYA = not tested due to just having added CYA last night
    CH = 125
    TA= 160
    I added 48oz muriatic acid and 45 oz liquid chlorine (10.8%) according to Pool Math.
    This evening, my TC is 3 and my pH is 6.8. Pool Math says to add 12 lb of borax. Really? With new plaster, I believe the pH will go up on its own, probably before I go to bed. I have one box of borax here. My question is: should I put it in and go out and get another, or sit tight and test again later tonight?
    It's raining here and the water is 60 degrees if that makes any difference. Our heater won't be working until tomorrow.
    This is all very new to me so I am hoping to get some reassurance and support here. Thanks in advance for your help.
    17K, IG, Gunite, 16x30 Rectangular, Beadcrete Water Blue, Hayward C4030 cartridge filter, 2 Hayward SP3400 VSP Variable Speed Pumps, Hayward T-Cell 15 Salt System, OmniLogic Automation, PCC 2000 Infloor cleaner, Coverstar auto cover, 3 deck jets, 3 Savi Melody LED lights, flagstone deck and coping, attached raised winterized spa, TF-100 Test Kit, SpeedStir, build completed 09/10/15.
    Jul 2015
    Kentucky
    1,124
    Re: First Test Results - Needs some help, please
    Hello. I'm so sorry your last thread didn't receive answers for your questions.
    What you can try on the pH 1st is the rain itself will help a little, but aim your jets at the surface of your water (where it is making bubbles on the surface), turn on any water features waterfalls, sprinklers etc. as the aeration from all of these will raise your pH for you.
    You didn't say how much stabilizer you added last night, but maintain your chlorine at the level for the anticipated CYA level. http://www.troublefreepool.com/conte...art-slam-shock I hope this helps. Please feel free to ask any questions you may have. We are all here to help. Have a wonderful night.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Your TA is high which will cause your Ph to rise. Also, new plaster causes PH to rise. So, you need to test it daily until you have a good understanding of how it behaves. It is important to keep PH between 7.2 and 7.8. Adding acid to lower your PH will slowly lower your TA, Pool School - Lower Total Alkalinity
    Your FC seems like it might be low. Chlorine level is set based on the Chlorine CYA Chart. Keep it at target and never let it drop below minimum to keep your pool sanitized and algae free.
    More on pool chemistry here, Pool School - ABCs of Pool Water Chemistry
    May 2015
    Toronto/ON
    40
    Thanks, Crackerjack4u!
    Yes, I read that about aeration and sent my hubby into the 61 degree water to splash around. we've also got our spa spillover running. Our deck jets aren't yet operational but that is a great suggestion about the jets (same as returns, right?)
    We added 77oz of CYA last night with the conservative goal of 30ppm.
    DFW, TX
    24,450
    I would skip adding Borax for now, your PH will rise quickly enough on its own.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,424
    Make sure to keep a running log of all of your tests results so you can see when things start to level out.
    Poor hubby! "Into the pool with you! SPLASH!" LOL
    Kim
    May 2015
    Toronto/ON
    40
    Thanks, pooldv. I'm going to start targeting FC of 3 based on an assumed CYA of 30 (added last night).
    Quote Originally Posted by kimkats View Post
    Kim
    kimkats, poor hubby indeed! As he said, he took one for the team. LOL Great suggestion about logging. I'm starting now.
    Crackerjack4u, after reading your post, we managed to figure out how to turn on the spa pump (called our PB) and it is now aerating quite fantastically! First time we've seen the jets in action. If only it were warmer, we'd have jumped right in!
    Jul 2015
    Kentucky
    1,124
    LOL I bet your hubby was about frozen when he got out from splashing around in that cold water Burrr.
    Yes, what I referred to as jets are returns. As pooldv mentioned above, there is no need to add any borax as the pH will rise enough on it's own because of the plaster, TA, etc., plus also be sure to keep the pH within the 7.2-7.8ppm range when it does go up, adjust with MA if it gets above that to lower it back down.
    In your circumstances, since it is too cold to swim there anyway, and all the things that will increase your pH anyway by themselves, there is probably no immediate need to aerate or anything else other than letting it rise on it's own because adding aeration, borax etc. could actually get it too high very quickly forcing you guys to then have to turn right back around, and lower it back down. So you might just want to just check the pH level daily, and just run your filter as usual with out the bubbles on the top, or any added features going until you can see how much it's going to rise on it's own 1st (as pooldv suggested) that would probably be advisable.
    If the other things don't raise it enough on their own within a couple days, (but we suspect it will), you can then add additional aeration to assist if needed. LOL So in other words, there's no need to send hubby back in for frequent splashing around to raise the pH at this time.
    LOL you guys have an awesome night.
    EDIT: But I am really glad you all got your spa pump figured out and got to see your jets in action. I bet you all can't wait for that heater to be working LOL especially the hubby.
    May 2015
    Toronto/ON
    40
    Thanks, Crackerjack4u! We'll be testing pH twice a day for sure.
    We are hoping for the heater to start up tomorrow. Our PB was apparently missing a part. It's funny b/c we just came out of a heat wave with temps over 100F, which is unusual for Toronto in Sept. It ended the day we got our plaster.
    Jul 2015
    Kentucky
    1,124
    LOL Bless your hearts It seems that the way it always happens. Hopefully the heater will be working soon, and by then your pH should be up where you want it. Have a wonderful night
    Jul 2012
    Tallahassee, FL
    30,424
    BUT you do NOT have to tell hubby that he does not need to splash around! "hummmmmmmmmmmm he did not wash the dishes-into the pool he goes again!" LOL
    Kim
    30,403
    Lepidoptera,
    Did you alter your pH test result in your first post? I read two people are telling you how to raise your pH when it is posted as 8.0.....already too high?????
    I am very confused.
    EDIT: I am sorry I didn't read down far enougfh in your post. I am no longer bewildered (at least for now)
    30,403
    Did you still need to discuss the sequestrant or is that resolved? Sorry I didn't respond earlier.
    May 2015
    Toronto/ON
    40
    Thanks, Dave. We decided to forego the sequestrant and hope for the best. Our PB didn't specifically encourage it. He just said "OK" and then asked to see the technical data sheet (it is just phosphoric acid if I recall correctly). We didn't pursue it. Hopefully that was the right decision and we won't see any metals coming out of suspension with these dramatic swings in pH.
    Incidentally, tonight we are measuring:
    FC 4
    pH 7
    TA 80
    Will test again in the morning. I'm so happy to see several experienced members pop into here to offer help and advice. Thank you!
    DFW, TX
    24,450
    Good numbers!
    Jul 2015
    Kentucky
    1,124
    Those numbers are looking great. Keep up the great job!! Have a wonderful night.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    hi,
    no need to test ph too often, every second day is probably enough unless you see dramatic changes
    just wanted to add there is a slight discrepancy with your ph
    if it was 8.0ph and you added 48oz of 31%muriatic acid that should equal 7.4ph
    not sure where the error is
    maybe pool volume, acid strength, amount of acid added or perhaps testing error
    try making smaller adjustments until sure where the error is
    anyway as already mentioned on fresh plaster ph will rise on its own
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Jul 2015
    Kentucky
    1,124
    Aussieta the OP's actual pH level is further down in the post. It was 6.8ppm. No chemicals were added at all. I hope that helps. Have a wonderful night
    Aug 2014
    Northern IL
    4,615
    Glad the hubby is getting into the fun of pool ownership!
  20. Back To Top    #20
    Sep 2013
    Connecticut
    728
    Quote Originally Posted by Crackerjack4u View Post
    Aussieta the OP's actual pH level is further down in the post. It was 6.8ppm. No chemicals were added at all...
    Aussieta's review of what the OP described (post #1 of this thread), including addition of muriatic acid to reduce pH of 8.0, looks to be accurate.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
