Results 1 to 10 of 10
Thread: Is this filter big enough?
    buccaneersdj's Avatar
    Aug 2015
    Largo/Florida
    76
    The Hayward C17502 / IG shockcrete 446 sq. ft. pool??? Says 175 ft2? Seems like other similar size pools on here have at least a 420ft filter, am I reading this wrong?
    17K gal IG Shockrete ff 30x20 446sq. 87' 3.5-6' sunshelf bub. 12" raised planter slv sf travertine 3' sheer descent 2 sconces brass Hayward StarClear Plus C17502 Cartridge filter Hayward AquaRite T15 Salt system Hayward Super 2, 2sp. 2 hp pump Hayward Colorlogic LED 1 pool in the deep 1 spa in shallow Coping Silver tumbled travertine Tile Noble Siren Decking 1500'Flagstone Cr/bg/ch Herritage
    Jun 2014
    15,078
    Re: Is this filter big enough?
    I've been doing some homework on your question, and I believe that the answer is not just a simple as looking at one variable (i.e. sq ft, or pool volume). Other factors such as the pump's GPM flow rate, head loss, additional water uses (i.e. waterfall, etc) can have an effect on the entire configuration of your equipment, to include filter size.
    There are several TFP threads that point to a filter size in excess of 400 sq ft as you noted. But you may want to read this page Hydraulics 101 - Have you lost your head? [Archive] - Trouble Free Pool that was put together by our experts some time ago. It contains great info. But one common theme holds true - it is quite common to install a filter slightly larger than required to increase efficiency and help reduce maintenance/cleaning times. It doesn't mean a smaller or original PB-assigned filter won't work as well. I myself have a 16x40, 18K pool with a simple Hayward C12002 filter. Could it be larger? - sure. Maybe if I knew then what I know now it would, but I suspect that with regular vacuuming I would probably still rinse it out just as much. With TFP-clear water, my filter holds quite well too.
    Not sure if I really helped you as you had hoped, but perhaps after this reply some other folks will chime-in with some more input.
    Feb 2011
    Petaluma, Ca
    665
    As I understand all the larger filter helps with is cleaning interval, doesn't filter any better, as said in the previous post.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    30,415
    What size pump you have is the most important factor.
    Aug 2015
    Largo/Florida
    76
    The pump is a Hayward Super 2, 2hp, 2 speed
    30,415
    You can go to the Hayward website and find the pump curve for that model. Using a head loss of around 50 (that suits most pools) you can then find your gpm of that particular pump.....say, maybe 88 gpm (just making an example)
    Then look for a filter that the gpm rating is around 25% in excess of that number....in this case 110 GPM and then get a filter rated at that or a little more.
    38,274
    For a cartridge filter, bigger is better. The only reason you need to worry about flow rates is if you are trying to use a large pump with a questionably small filter.
    For a 17k gallon pool in FL, I would want a minimum of 250 sqft. So 175 sqft is not much on the small side.
    Aug 2015
    Largo/Florida
    76
    Am I reading this chart right? If so, the biggest residential filter on this model Hayward is 200 sqft???
    38,274
    They have different designs that go much larger.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    The larger the cartridge filter the longer the cycles between cleaning. Hayward makes a few different types with one going all the way to 700 sq Ft. The larger filter will in many cases reduce running pressure and increase flow.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
