Thread: Is the Alkalinity Test reliable at High FC Levels while Slamming?
    Aug 2015
    Melville, NY
    9
    I know the PH test is not reliable at high FC levels while slamming, is the Alkalinity test also not reliable?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Is the Alkalinity Test reliable at High FC Levels while Slamming?
    It is, but make sure you put in the R007 reagent so that it doesn't turn yellow. Even if it does, the result is still fine, but the important thing is, that you really should not be worried about TA during a SLAM. Why are you concerned with it?
    Essential Links:
    30,414
    Absolutely. During a SLAM, the ONLY test that should concern you is FC.
    Aug 2015
    Melville, NY
    9
    I was just curious, you're right I should only be concerned of FC.
