Thread: Hi All
    Aug 2015
    San Diego, CA
    16
    Hi All
    New to this forum but pool owner since 15 years. Looking soon for advice here on installation of variable speed pump.
    27,000 gal in ground white plaster pool. Sta-Rite System 3 DE filter, Sta-Rite heater and 2 HP pump. Solar heating on roof.
    Jun 2014
    15,176
    Re: Hi All
    Hello, and welcome to TFP!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Hi All
    Its an easy DIY installation.
    Just connect the plumbing to the pump, and connect the power cable to the pump and you're done.
    Quote Originally Posted by Tapio View Post
    Divin Dave,
    Aug 2015
    San Diego, CA
    16
    Re: Hi All
    Quote Originally Posted by Divin Dave View Post
    Yep, that's the easy part. I am interested in an actuator valve for the suction cleaner. A controller which will run that and run the different pool speeds also. I will post my questions in the Pumping Station.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Hi All
    Welcome to TFP! VS pumps are great!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Hi All
    Welcome to the forum!
