Thread: Jandy SWG Boost Button
    Aug 2015
    Austin, Tx
    9
    When should I use the boost button on my SWG? Should I use it instead of shock once a week? New to SWG, thanks for your help!
    In ground pool with pebble tech plaster. 15100 gallons with Jandy 2.0 hp variable speed pump and an Aqua Pure 1400 Fsoft SWG. Has an Ice Breaker heat pump and Jandy cartridge filter.
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Re: Jandy SWG Boost Button
    Hey there MaLi
    The boost buttons on SWG cause the cell to go into high drive (like 100% for x hours) which is actually kind of hard on the cell when you consider that a cell's lifespan is y hours. If for some reason you feel a need to raise the FC level of your pool quickly, a much better way is to use liquid chlorine aka " Household Bleach".
    Liquid chlorine gives you the instant rise in FC whereas SWGs are meant to *s-l-o-w-l-y* and steadily maintain your chlorine.
    You should never have to "Shock" your pool if you keep your FC and CYA at proper levels. Have you read up in PoolSchool (top right of this page) to learn about the ABC's of Water Chemistry??
    Good reading for new pool owners
    Jun 2011
    Long Beach, CA
    2,790
    Welcome to TFP!
    Weekly shocking is not required by TFPer's if you follow our suggestions. To get you going in the right direction I suggest start by reading the following, Pool School - Water Balance for SWGs, and ABC's of Pool Water Chemistry.
    Aug 2015
    Austin, Tx
    9
    Thanks all, I'll read those articles!
    Aug 2015
    Austin, Tx
    9
    What would be an instance in which I would want to use the boost button?
    Jun 2011
    Long Beach, CA
    2,790
    In all my years I've never pushed the boost button. Whenever my pools needs a boost I add liquid chlorine as it instantly raises the chlorine level to the amount that I want it raised to.
    The circumstances that usually require a quick raise is before and after a large swim party or if I measure the FC below my minimum recommended FC level, Chlorine CYA Chart.
