Thread: Grout Dark Stain
    Mar 2015
    South Florida
    43
    Grout Dark Stain
    Some dark spot started to show up on the grout above the water line. Any clue?
    12K gallons, IG, Durazzo, Pentair cartridge filter, Jandy ePump JEP2.0 VSP , Pool started March 2, 2015, South FL
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Grout Dark Stain
    What do your water levels look like? FC, etc? How do you test and treat your pool on a daily, weekly bases?
    Kim
    Mar 2015
    South Florida
    43
    I test chlorine and ph daily, the rest mosthly weekly
    PH - 7.5
    FC - 4
    CC - 0
    CH - 375
    TA - 80
    CYA - 70
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Are you running the Nature 2 in your signature? It could be metals splashing. It also could be mold or algae if you are not brushing regularly. Last, I would keep the FC higher with a cya of 70. I'd target 7 to 8.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jul 2012
    Tallahassee, FL
    30,585
    If you look at this chart you are below the min. FC for your CYA.
    Pool School - Chlorine / CYA Chart
    Do you have an pucks? Try rubbing one on the dark spot and see what happens.
    Kim
    Mar 2015
    South Florida
    43
    I only used the Nature 2 with the initial cartridge for about 3 month. I brush once a week. I have tried spraying regular bleach and brush locally, but not change. I will increase chlorine just in case.
