Thread: does x all at once = 1 every x days?
    Jul 2012
    Whidbey Island, WA
    397
    Pool consumes about 1gal bleach per day in this weather.
    If I put in 2 gal, will it last 2 days?
    If I put in 3 gal, will it last 3 days?
    or
    Does it not work that way?
    Thank you.
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Jan 2014
    Buckeye AZ
    807
    Re: does x all at once = 1 every x days?
    all the FC you add above the saturation for your CYA level will be not be well protected from the sun by the stabilizer. Higher FC levels will degrade faster. (and, higher % above CYA level). there is a chem geek chart with the curves on it..
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The short answer is no, it doesn't work that way. The higher you raise the FC, the faster it goes down. Plus, you'll be raising it above high limits which is not good for you, or the equipment.
    Essential Links:
    Jul 2012
    Whidbey Island, WA
    397
    thank you both
    think I found the charts and will study up
    I suppose then if gone 3 days in sunny weather should open up the Rainbow
