Thread: Swg for 25500g
    Jul 2015
    O-H-I-O
    29
    Swg for 25500g
    Hi all,
    what swg would you recommend for a 25500 gallon in ground pool? PB likes pent air but reviews look suspect on some sites? He's coming tonight to finalize details. Thanks
    Jun 2011
    Long Beach, CA
    2,790
    Re: Swg for 25500g
    There are many satisfied people at TFP with Pentair SWG's. If your pool has Pentair automation then it will be a perfect fit for the system. If you don't have automation then the Pentair SWG's can be a little difficult to dial in the output needed to make the right amount of chlorine since it can only be adjusted by 20% increments.
    Whatever brand of SWG you decide on make sure it is rated between 40,000 to 60,000 gallons.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Swg for 25500g
    If you are not going to have an automation system, I would suggest the AquaRite T-15 (Hayward). It has the output you need for that size pool and you can set the output control in increments of one percent, which is not true of the Pentair. I have one and the T-15 cell lasted 7+ years, making my chlorine cost about $57 per year. The only problems I ever hear of are a resistor that can fail. The part cot $2.50 to replace and takes about a half hour. Mine had to be fixed after ten years of service.
    Your pool builder may be using all Pentair equipment. Many builders have a discount arrangement with one manufacturer. My PB used all Hayward, I have since changed out some equip. So I pick and chose. Pentair pump and solar control, Hayward SWG, etc.
    chiefwej
